Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 07-02-2008, 06:34 PM
dave91 dave91 is offline
Question Air Conditioning problem 2001 Crown Vic
I had my air conditioner recharged and now it's not giving me cold air. I have a 2001 Crown Vic, 40,000 miles. The bottom metal line coming off the firewall unit is cold up until the first coupling. Then the cold stops. I am really fustrated here. Does anyone have any ideas?
Old 07-24-2008, 05:51 PM
dskap dskap is offline
Re: Air Conditioning problem 2001 Crown Vic
I'm not a mechanic but it sounds like some kind of blockage. When in the shop after recharging, did they not check to see how well your air temp was?
Did it work properly when you left that shop? Did it work at all before charging?
Old 07-24-2008, 07:17 PM
rhandwor rhandwor is offline
Take it back to the shop who recharged it and ask them to fix it for you free.
Old 07-24-2008, 08:33 PM
It was warm before they charged it. I thought it was working. Taking it back in on Monday. I'll let you know what they find
Old 07-25-2008, 07:46 PM
fleettech fleettech is offline
sounds like a plugged orfice tube
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 07-25-2008, 09:54 PM
dieseltechcv's Avatar
dieseltechcv dieseltechcv is offline
Yes, it has to be the orifice tube, but how often does the compressor cycles?and if you go back to the mechanic and they don't fix it tell us what the pressure readings are and check ambient temrerature if you give me that information we can easily dagnose. I mean they should have done that when they recharge, and they should have seen that orificie tube or expansion valve wasn't working right anyway, your problem has to be fixed by a good mechanic, because they have to properly dispose of the refrigerant.
