Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 07-02-2008, 06:21 PM
jduke44 jduke44 is offline
wipers stop in up position
Hey guys, I hope you can help me. I have a 2000 chevy venture and my wipers stop in the up position when I turn them off. Everything else seems to work. Is there a way to know what would cause that. I'm getting people telling me that the motor may be out of whack and to adjust it (how would you do that ), the wiper motor needs replacing and possible the pulse board can be culprit. Any ideas? Thanks.
Old 07-03-2008, 12:44 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: wipers stop in up position
Try looking through these threads which have addressed the issue in the past:
http://www.automotiveforums.com/vbul...d.php?t=285312
http://www.automotiveforums.com/vbul...d.php?t=499402
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 07-03-2008, 05:04 PM
Thank you. I did do a search for wipers before I asked but these didn't come up. I will try these suggestions.
Old 07-04-2008, 12:41 AM
Also check the "sister forums", Pontiac Montana, and Oldsmobile Silhouette as they too experience the same issues.
Old 04-28-2009, 06:41 PM
elag elag is offline
I know this thread is over a year old but I'll answer it anyway for other people.
I had the same problem. Searched all over the internet, even asked a couple of mechanics I know. Could not find anything that solved the problem. Finally I took the cover off and watched the motor as I cycled it on and off. I noticed that at the top of the wiper motor assembly there is a small metal pin (vertical). I took a screw driver and moved the pin side to side a couple of times. While doing this I sprayed some WD40 (loosing oil) around the top and side of the wiper motor assembly. After I did this the wipers worked perfectly. Parked every time.
Now that I had it working. I knew that WD40 dries up quickly so I used a oil dropper and put some motor oil on the moving parts. I haven't had a problem in a year now.
