Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 07-02-2008, 06:00 PM
Avenger985 Avenger985 is offline
Toyota Key wont come out
I have a 98 Toyota camry LE L4 engine. I got into a car accident and am trying to fix the car myself. So far I have replaced the radiator, lowere control arm, lower ball joint, and shifter cable. I am having a problem with the ignition key. I can stick the key in the ignition and start the car but when I try to take out the key, it wont come out. The only way it will come out is if I disconnect the battery. Anyone got a clue what it could be. Do I just need to replace the igntion lock?
Old 07-03-2008, 10:22 AM
somick's Avatar
somick somick is offline
Re: Toyota Key wont come out
If the disconnect of power solves the problem it may be some relay that got damaged after the accident. Download your car's repair manual and start from there. The link to the manuals is at the top of the Toyota forum.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 07-05-2008, 10:29 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
My first guess would be that the shifter is not recognizing the car as being in 'Park' or 'Neutral'. The key will not come out unless the park/neutral safety switch is engaged. Perhaps when you replaced the cable you didn't adjust for slack or the switch was damaged or disconnected during replacement? Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
