Old 07-02-2008, 12:21 PM
blackbeltbaby blackbeltbaby is offline
Dash Lights and Clock Don't Turn On
I just bought a '99 Grand Am GT last week. We bought it during the day and didn't think to check to see if the dash lights worked. Unfortunately when we got it home we realized that the dash lights and the clock radio light do not work. Our first thought was that maybe the lights were burned out. However, when I turn the key to battery power, the radio clock works but the dash does not. As soon as I start the car, the radio lights go out too. Any ideas and help would be greatly appreciated since I cannot drive my car at night right now.
Old 07-02-2008, 12:50 PM
inafogg inafogg is offline
Re: Dash Lights and Clock Don't Turn On
simple things 1st!!have you ck the dimmer control??
Old 07-02-2008, 12:55 PM
I've tried turning the dimmer switch up and down and nothing changes. I don't know of any way to check it other than that.
Old 07-02-2008, 01:54 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Fuses?
Old 07-02-2008, 02:02 PM
Sorry, I forgot to mention that we have checked all the fuses and they all are perfectly fine.
Old 07-02-2008, 02:40 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF blackbeltbaby !!
Did you check all three fuse boxes ?
pass side A, & G could affectt these, drivers side, check H, I and K i think...
Notice anything else not working ??
1999 Grand Am SS 3.4 OHV
Old 07-02-2008, 02:48 PM
We did check every fuse in all 3 fuse boxes. The only other thing odd with the car that we noticed was that several warning lights were on, but was told by the mechanic that it was related to a sensor with the brakes that need replacing. Which makes me even more perplexed since I know that the warning lights on the dash do work.
Old 07-02-2008, 02:53 PM
Sounds like you have your hands full.
Did they give you any trouble codes ?
Only other thing could be the wiring has been messed with in the dash..
It is probly going to need a Dealer scan tool to figure this out, with out any codes youre just guessing.
Old 07-02-2008, 03:51 PM
Andrew Martin Andrew Martin is offline
That dimmer switch could very well be bad, or even just unplugged. A local salvage yard would probably only charge several dollars for one. That's a good thing to try before going to any mechanics and doling out hundreds of dollars for something that's only worth a few bucks. =P
2000 Ford Taurus SE
Ethanol FFV
3.0 Vulcan, AX4Shit
Old 07-02-2008, 08:05 PM
Good Point Andrew! Its pretty easy to pop off the bezel that holds the dimmer/fog switch.
Use a straight screw driver or panel tool , lift on one of the corners and it should pop out, here is a pic...
Old 07-03-2008, 03:31 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Xero, is there anything you didn't paint green on that car?
Try moving the key around in the on position (with the engine off incase you bump "start") and see if you get the lights to flicker. Since they work in "ACC" but not "ON", it makes me think ignition switch.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-04-2008, 02:42 PM
Yeah, I Do like to paint stuff , and green is one of my favorites.
I would agree with the ignition switch possibly being the trouble, I've seen a couple that did simular things with a bad switch.
Thier is a testing procedure here.....
Ignition switch-Lock Cylinder check/replace 99+ Grand am's & some other N-bodies
