Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 10-17-2001, 07:40 PM
Chekmi21 Chekmi21 is offline
Send a message via AIM to Chekmi21
Do I Really Need New Shocks???
If I was to lower my car only like an inch...would I really need everything new or could I just use the stock stuff and be ok? Like if I got TEIN's or Eibach...would I be ok just lowering my car a little and not doing anything with the stock parts? on a p11
Old 10-17-2001, 08:09 PM
P10DET's Avatar
P10DET P10DET is offline
Re: Do I Really Need New Shocks???
Well, first of all, the Tein's are spings and dampers.
Second, you can use the stock dampers, but I wouldn't. They will be way under damped for even modest lowering springs like Eibachs. They will likely give up the ghost a lot sooner as well.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 10-17-2001, 08:48 PM
So the TEIN's are springs and dampers...what are dampers?
So if I got the TEIN's...what else would I need to buy for my car?
I heard that if you lower a car the ride becomes really stiff. But I was also told if you buy the coilovers and shocks and everything then you would have a lowered car but with a ride almost that of stock. Is that true?
Old 10-17-2001, 10:18 PM
P10DET's Avatar
Shocks and struts are dampers. They damp the oscillations of the springs.
What most people think of as a stiff ride in a lowered car is the car bottoming due to springs that don't have a high enough weight to keep the car off the bumpstops. This can be combated by using short body dampers that retain the stock suspension travel (or at least have more travel).
You cannot get a stock ride, but you can get pretty close. I am running 275# front and 200# rear springs with KYB AGX. It's a pretty good ride. I think with Konis I'd have a ride that is pretty near stock.
George Roffe
Houston, Texas USA
00 328i
Old 10-18-2001, 09:10 AM
Nismoboy1's Avatar
Nismoboy1 Nismoboy1 is offline
Send a message via AIM to Nismoboy1
you can Tein springs alone...they're called TEIN S.Tech. You can get them with either a soft or medium spring rate, depending on how you drive. For stock parts i'd opt for the soft springs...they make them for P10's also.
John H.
2001 Infiniti G20t - Aspen White Pearl
For Sale: 18" Gold Axis Se7en's and Eibach Pro-kits also for a G20 P11. Check the Infiniti G20 Classifieds Here
***My G20 - Click Here***
Do i need new shocks? My supension is making noise. happyhead Tires and Wheels 8 02-17-2003 05:27 PM
Do I need new shocks or springs? Rapidito '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 11-20-2002 12:16 PM
i need new shocks! 95_G20_P10 Suspension 5 05-02-2002 09:59 AM
Do i need new shocks? pche059 Suspension 7 10-25-2001 01:37 AM
