Old 07-02-2008, 12:08 AM
RDOMING RDOMING is offline
Exclamation car starts and dies out, security light on solid (not blinking!)
NO START SOLUTION: 2000 Alero, 2.4L, turns over but doesn't start, security light turns on then off then after a few seconds light turns back on SOLID, SOLUTION: repaired corroded terminals on BCM (located on passengers side under the dashboard). Humidity from blower or other source leaked onto terminals and coroded them away. The symptoms actually started months ahead of time. First the door locks stoped working, then the door chimes and lights, finaly the car failed to start. It would turn and run for about a second and then die out. The security light would remain on solid. The 10 min reset doesn't work in this case.
Old 07-02-2008, 07:45 PM
03CavyMan 03CavyMan is offline
Send a message via AIM to 03CavyMan Send a message via MSN to 03CavyMan
Re: car starts and dies out, security light on solid (not blinking!)
Good tip, I've seen this a few times before at work.
2000 Chevrolet Silverado Regular Cab Short Box
4.3L Vortec - 5 speed
Ion Alloy 16x8" chrome wheels
Magnaflow Catback Exhaust
K&N Intake, Throttle Body Spacer
GM Automotive Technician
Previously - 2003 Chevrolet Cavalier
