Old 07-01-2008, 09:38 PM
Godofwarmike's Avatar
Godofwarmike Godofwarmike is offline
Brake Help.
Ok so i just bought a 1994 Grand Prix Coupe. 3100 V6 SE. And the seller told me it had new rear brakes but would need new fronts to pass. Upon taking them apart it is true. The worst rotors ive ever seen. One problem i cant get the caliper bracket off that is holding the rotor on. the Torx head bolts are STUCK in there not budging at all. i tried leaving PB Blaster on there overnight but still the same as before. More leverage doesn't help at all and tapping on it with a hammer doesn't either. Im going to try heat tomorrow it is my last chance unless someone has an idea. I don't have much money to go on since i just spent 1200 on the car and brakes for the front. Any ideas would help.
Old 07-01-2008, 09:55 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Brake Help.
Those bolts are installed with threadlock. A little heat, and they should come right off.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-02-2008, 12:26 AM
fastyz400 fastyz400 is offline
Re: Brake Help.
High torque impact wrench. Breaks away anything. I've never had trouble with rusty caliper bolts.
Old 07-02-2008, 08:55 AM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Re: Brake Help.
Make sure you try the heat before you try to impact them off! I have seen the impact break an endless amount of bolts!
Old 07-02-2008, 09:08 AM
RaeRae1's Avatar
RaeRae1 RaeRae1 is offline
Send a message via AIM to RaeRae1
Re: Brake Help.
I agree about the heat first. Impact wrenches can definitely break bolts.
Blessed are the cracked ones, for they are the ones that let in the light.
Originally Posted by 72chevelleOhio
Your cheer-mobile needs a flat tire.
Old 07-02-2008, 09:17 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Brake Help.
Just get a torx bit (correct size), put it on a long half inch breaker bar, turn the wheel in the direction to give you the most room, and reef on them. You'll more than likely twist the torx off before you break the bolts.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
