Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-01-2008, 12:55 PM
Laramore Laramore is offline
Gas in air filter
Hello all,----1990 Cutlass Supreme, 3.1, v6, od=140k
My cutlass has been acting up again. Its become hard to start, you have to keep cranking and give it gas or it will not start. Then when it is started it dies unless i shift it to nuetral and keep some gas on it even while driving, if i let off the gas in drive it dies, it surges in idle intermentantly in park if it manages to idle for a minute. i opened the hood and found gas inside the hose that connects the air filter box to the manifold, the 4 inch black hose. i had found one of the spark plug wires undone, but i doubt that will cause gas to back up like that. Also the vacuum lines that connect to the FPR were disconnected with gas in side them.Also the check engine light comes on but throws code 12 only for 3 times when i jumper the top righthand terminals with a wire. nothing but code 12. which means nothing i think.
Please help before car blows smooth up.
Old 07-01-2008, 02:44 PM
maxwedge maxwedge is offline
A990 racer
Re: Gas in air filter
If fuel was in the FPR hose the FPR is bad, loading up the engine, replace it and change the oil also.
Old 07-01-2008, 03:07 PM
ok i price checked one and its like 200 dollars for a new one. i guess ill look in a junk yard for one.
thanks max
