Old 07-01-2008, 12:47 PM
Jess12680 Jess12680 is offline
!992 Buick LeSabre A/C problem
My Dad owns a 1993 Buick LeSabre,the A/C always worked then the compressor went,was replaced and filled and now they can't get the A/C to work.Any suggestions??? Thanks in advance
Old 07-01-2008, 02:26 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: !992 Buick LeSabre A/C problem
Did "they" replace the expansion valve (orifice screen), accumulator and pull a vacuum on the system? What happened to the original compressor, did it lock-up, or just quit cooling? Was this a conversion to 134a?
Old 07-01-2008, 10:31 PM
It locked up on him and a mechanic replaced it,now said it is electrical but said $100.00 per 30 minutes to diagnose.I will ask my dad about the expansion valve .Thanks for the reply
Old 07-02-2008, 09:42 AM
HotZ28's Avatar
AF Moderator Elite
THAT IS A FLAT RATE OF TWO HUNDREDS DOLLARS AN HOUR!!! I have never heard of any mechanic charging that much!! What does the mechanic think he is; a brain surgeon? If the compressor locked-up, more than likely the orifice screen was blocked with debris. If so, the system would require a complete flush, otherwise, even if they did replace the screen, it would fill with trash again and the pressure switch would not allow the compressor to operate. You need to find out exactly what this mechanic is doing, before he totally drains your dad's wallet!
Old 07-02-2008, 03:17 PM
Jrs3800 Jrs3800 is offline
Agreed.... When a Compressor goes bad, At the bare minimum the Orifice Filter, and the Reciever/Drier should be replaced...
Here is an example of what HotZ28 is talking about... Its the same filter the 93 Buick uses...
As you can see replacing this is a must...
Old 07-02-2008, 11:02 PM
happydog500 happydog500 is offline
This looks interesting. How do u get to this? I have a 97, is it in the same place?
Wonder if it's good to go in and clean/change it on a car that has air working?
I've never heard of this. Anything else u can enplane about this thing?
Thank you very much,
Chris.
Old 07-06-2008, 03:00 AM
spinne1 spinne1 is offline
Chris.
On a 92 it is likely in the tubing near the joint between the tubing and the condenser or in the condenser tubing near said joint (I can't remember exactly.) I don't know about a 97 (it will likely be in an area of tubing that is straight and big enough to hold it--but could also possibly be near the joint between the tubing and the evaporator.) As for changing it, it is not a user serviceable part. You cannot access it without first removing the refrigerant. If your car's air works fine then there is no good reason to change it. It will only get clogged like in the picture if there has been damage to the compressor causing metal shards to get loose and then lodged in the filter. Your car would not likely have a filter looking like that.
Old 07-09-2008, 09:25 PM
ChemMan ChemMan is offline
So the shop that worked on it now can't figure out what is wrong with it?!?!? Time to find a new mechanic!
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
