Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 07-01-2008, 12:25 PM
KarbonXIII's Avatar
KarbonXIII KarbonXIII is offline
Questions about 283
I just bought a 71 Pontiac LeMans a few days ago and am kinda puzzled about this engine. Now apparently this car has only been driven by old ladies since it was bought, but I dont think the engine is still stock.
I really dont see them changing the engine for shits and giggles lol.
Anyways, we first thought that the LeMans had the 350 but we checked the block number online and it came up as a Chevy 283.
I'm just learning about cars for the most part, so I'm wondering if anyone can help with information about getting parts for this.
The mechanics seem as clueless as me lol.
Just want to know how to look for parts for this particular engine. they always want make and model, and all I know is that its a chevy 283.
Old 07-01-2008, 12:54 PM
MrPbody MrPbody is offline
AF -Advisor
Re: Questions about 283
HHHHHHHMMMMMMMMMMM........ Okay, a Chevy V-8 has four bolts holding the water pump to the block. A 283 is an "early" small block, so it has an oil filler pipe sticking out of the intake manifold in the front, leaning to the driver's side. The dipstick is a little more than 1/2 way back on the driver's side. The spark plugs go in "straight" and "level". The exhaust manifolds wrap around the plugs, making them difiicult to get to.
A Pontiac V8 has no oil filler pipe. It has a screw-in cap on the driver's side valve cover. The dipstick is a little less than 1/2 way back on the passenger's side. The water pump for a '71 would have a total of 11 bolts holding it on, 9 with 1/2" heads, two with 9/16 heads. The spark plugs are above the exhaust and quite easily accessed.
I describe this as there are some "overlaps" in casting numbers, and not always the best way to identify engine. Also, no '71 LeMans came from the factory with a Chevy engine in it (except the straight 6s), and it's not trivial to switch them.
If it IS a 283 for sure, when ordering parts that are attached to or installed IN the engine, those for a '66 Chevelle with a 283 should "fit". Everything else should be for the 350 LeMans.
This all sounds a bit bizarre... Any chance you could post a pic?
Jim
Old 07-01-2008, 05:38 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I'm with MrPbody on this, although a casting# for a 283 could also be used on an early 307.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-04-2008, 12:36 PM
KarbonXIII's Avatar
I just uploaded a bunch of pictures to this link.
http://picasaweb.google.ca/KarbonXIII/Cherry
Warning! Big files I didnt resize them at all.
Old 07-04-2008, 12:48 PM
KarbonXIII's Avatar
Oh and another question. I just bought a set of chrome valve covers, and well suprise! staggered bolt configuration.
Whats the deal with that? where the hell do I get staggered bolt valve covers?
I found some for a vette but they were like 300 bucks.
That and the valve covers which were for a chevy 283 btw, seemed too wide.
depth wise.
Old 07-04-2008, 03:07 PM
silicon212's Avatar
Confoundingly Lucid
Your engine is enigmatic.
It is a Chevrolet small block.
It looks like it was thrown together with parts left over from something else. The valve covers that are on it now are what was basically used from 1969-1986, so a staggered bolt configuration doesn't make sense. The small block did in fact use staggered valve cover bolts, but only from 1955-1957, and there was a 283 in 1957 but it may or may not be what you have. However, the valve covers on it now only came in a square configuration, that is - the upper and lower bolts are positioned the same. The driver side cylinder head looks as though it doesn't have bolt holes for mounting accessory brackets, which would make it pre 1969. Looking at the bracket for the alternator, which looks as though it has a fabricated bracket behind it, the passenger side head might also be from the same era.
Can you post the block casting # here for us, please?
What's with the gray primer on the driver exhaust manifold?
Old 07-05-2008, 12:58 AM
KarbonXIII's Avatar
So today was a fairly successful day, got it all buttoned up and fired up (first try ) and man does it sound nice.
Thats where the night turned lol. Once she was running we decided to put the new steering wheel on and replace the ignition, and thats where things stopped working well.
Theres no release screw to take out the ignition on the 71 pontiac steering column if it is the origional to start with.
but the ignition is working now, so we're going to try and fix our mistake tomorrow, i'll get the block number we have it written down somewhere.
oh and the primer was just an experiment to hide the ugly rust covered manifold. lol.
Old 07-05-2008, 08:20 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Just a bit of background on this car. According to the profile, this member is in Edmonton, Canada.
Given the member's location, I assume this is a Canadian-made Pontiac due to the Chevy engine.
Virtually all Canadian - made Pontiacs from the mid - 1950's to the late '70's had Chevrolet six and V8 engines in them. The A-body (Tempest) and full - size Pontiacs were made in Canada for the Canadian market so they have Chevy engines.
Some Pontiacs sold in Canada had Pontiac engines. These were models that were assembled in the US and shipped to Canada, and include the GTO and Firebird.
In this case, it is probably likely the Chevy engine is original. Any decent Canadian parts store would order parts for you based on model and year. If not, order engine parts suitable for a '71 Chevelle with a 307.
IMO lots of Canadian made mid-size Pontiacs in the early '70's came with a Chevy 307. IMO assume that is what it is and not a 283.
BTW lots of older American car enthusiasts think we are loopy for having Chevy powered Ponchos. IMO our Mercury and Fargo pick up trucks are more unique.
Old 07-05-2008, 11:19 AM
silicon212's Avatar
Confoundingly Lucid
I had a 1975 Pontiac Grand Am in which my sister blew up the original 400 in 1993; I replaced it with a Chevy 350 (the engine that is now in my Caprice and still going strong, 300k later).
So, I, for one, would not think anyone would be loopy to have a Chevy SB in their Poncho.
Old 07-06-2008, 08:11 PM
KarbonXIII's Avatar
UGGGHHH I love this car. Everything is running smooth and sound and man she feels good.
sorry i havn't found the block number, been busy just getting everything done new steering wheel exhaust tips etc.
Just took her out for a good ride, get everything nice and hot.
Old 07-07-2008, 12:54 PM
AF -Advisor
MagicRat is correct about Canadian Pontiacs, though I've never seen one like this one! The "Beaumont", "Arcadian" and "Parisienne" (pre-'76) were all Canadian "Pontiacs" and did indeed, had Chevy engines. I would bet this one is a 307 as MR says. If the car is a relative stone, that's it for sure. Those cars are too heavy for such a small engine (IMO).
Nice looker. Prime candidate for a 461 if I've ever seen one...(:-
Jim
Old 08-01-2008, 01:04 AM
KarbonXIII's Avatar
Well whatever happened it runs great, just gotta figure out what kind of engine i'm going to spend the dough on and drop in.
Old 08-01-2008, 08:36 AM
AF -Advisor
A smart man once told me: "If it ain't broke, DON'T fix it!" But...
If you want more power with the least amount of effort and expense, a 350 or 383 (stroked 350) Chevy would be the easiest/most expeditious method. I would opt for the 383 due to the superior low-end torque production, and a relatively heavy car. The 400SB is okay, but not known for durability in a "driver" when power is up.
If you want the car to be both streetable AND fast, you will need a bigger engine. A big block would be fairly easy to install, as the Chevy wiring is already present. A big Pointiac would have a similar effect and provide a little better handling (lighter than BBC) and a tad more low-end torque. Significant amount of changes needed to put one in there, but ALL the parts are readily available from several suppliers.
Small block fans, don't get upset. A small block can be made to be VERY powerful, but once a certain level of power is reached, they're not very friendly to drive in a 3,600 lb. car... Both the BBC and Pontiac are better for a heavier streeter due to superior torque production at lower RPM (IMO).
Jim
Old 08-01-2008, 11:47 AM
luxeryvic luxeryvic is offline
what do u mean not very freindly to drive in a 3600lb car? to light of a car for to much power?
Old 08-01-2008, 01:30 PM
AF -Advisor
Example: A 500 HP 383 small block makes about 425 lb. ft. of torque, with the curve starting to really climb around 3,000, peaking at about 4,800. (you could build one that makes more torque at a lower speed, but peak HP would suffer)
In order to make that much horsepower, a camshaft of at least 240 degrees of intake duration (@.050" lift) is necessary. A cam like that will not have a very good idle quality ("fidget" is more accurate than "idle"). In order to drive it in traffic, it would require a fairly high stall speed for the torque converter, generating a tremendous amount of heat in the transmission fluid, shortening the life. If a manual transmission, it would require a very "stiff" rear axle final drive ratio (higher numeric), which will keep engine speed up in the power band. This is known as "rattling your teeth".
A well done 454 making the same 500 HP, will make more than 500 lb. ft. of torque, and at a lower engine speed, starting the curve in earnest in the 2,500 range, peaking right at 4,000.
The car would require a much more "tame" camshaft, in the 220 @ .050 range, making much more vacuum for accessories, no need for a high stall converter, and "taller" (lower numeric) rear axle ratio will provide the same level of accelleration as the smaller engine with the stiffer gear.
The Pontiac has even more desirable low-speed power production features than BBC. No doubt, most know the reputation GTO has, and also have heard how their heavy cars don't seem to be nearly as affected regarding performance. This is why.
So, for a race car (lives on a trailer, NEVER sees the street), a small block is, for many good reasons, the most popular engine on the planet. And it isn't most popular because it's "cheap". It's cheap BECAUSE it's the most popular... But for a high performance street car that is fairly heavy (>3,500 lbs.), the bigger engines have a definite advantage. The time-proven success of both SS396 and GTO bear that out. Even today, both of those cars are at the top of "the list" for desired street performance cars. 2nd gen Firebirds and Camaros have pretty much taken over simply because the lack of availability of the good A-bodies from over-collecting or attrition. But those same F-bodies use big engines to do what they do best. I give the Firebird a slight "edge", as the Pontiac has better overall balance. Big block Camaros are nose-heavy and small block Camaros have the power limitations discussed here.
I have tried to explain it as objectively as I can. Most of you guys know I'm a Pontiac bigot, but it comes from study and logic, not simple "brand loyalty". Fords and Dodges are a whole different matter... Hard to argue with a well done 440!
Jim
