Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 07-01-2008, 08:26 AM
Peter E Peter E is offline
99 venture head gasket???
Hello folks
I have a 99 venture with 200,000 km on it. Recently it has started to overheat and lose coolant (no external leaks). There is also an occasional misfire code PO302. I pulled the plug on cylinder 2 and it looks fine. There is no coolant in the engine oil, and the rad pressure test came back fine (it held 15 psi for several minutes).
Could it be a bad head gasket and still hold pressure? The car drives fine other than a slight miss, probably ignition related. No puddles or white smoke..
thanks for any advice
Old 07-07-2008, 02:39 AM
rockwood84 rockwood84 is offline
Re: 99 venture head gasket???
does the temp gauge fluctuate up and down? or does it just keep getting hotter?look under the oil cap for a white mayonaisse and on oil dipstick. how long since you replaced the thermastat?
