Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 07-01-2008, 01:02 AM
Mitchman90 Mitchman90 is offline
Noise from trunk
I have just purchased a 94 jetta and I have several questions. I will start easy I here a sound from the trunk when I unlock the door, then goes away, what is it. Thanks for the help and the beginning of a car dork..
Old 07-01-2008, 12:31 PM
Doug Tatham Doug Tatham is offline
Re: Noise from trunk
Let the guy out of your trunk.
Sorry, couldn't resist.
Your seals on your door are probably really good and you create a bit of a vacuum when you open it. Check to make sure the weather stripping around the trunk is intact and if so, adjust the catch so that it holds the trunk down tighter.
