The front brakes on my blazer are engaged? Pulled the ABS fuses thinking maybe it was the module, no results... pads and rotors are new... Any help
Re: 2000 ZR2 front brakes will not disengage?
Open bleeder and if they release it is pressure build up.
Check front brake hose or crack open brake line in front of brake. If bleeder open does not take off pressure it is a sticking caliper piston or slider pins. Did you lubercate slider pins?
thanks for the tips, will give it a shot... and yes I did lube the pins
You are welcome and let us know how it goes.
MT
all is well for now, you were right... Thank a Million MT
You are welcome and glad you found the problem.
Where was the problem? MT
