Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-30-2008, 09:50 PM
Gsst98's Avatar
Gsst98 Gsst98 is offline
Send a message via AIM to Gsst98
Turbo about to take a crap?
Just recently my turbo when it hits full boost set at 15PSI its a T-25. It begins to stutter almost like hitting the redline. The needle goes crazy pinning up and down at 15psi and the car stutters. I turned the bosot down to 12 and it does it occasinally. Someone told me this was a sign of the turbo going bad is this true?
Old 06-30-2008, 10:21 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: Turbo about to take a crap?
those the simptoms i had once, basic dsm stuff here, check for boost leaks and check your spark plugs. mine was at.032 and i put it at 26 and then it was nice and smooth again.
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 06-30-2008, 10:41 PM
Gsst98's Avatar
I checked the plugs there good but I havn't had the time to check for any boost leaks.
IS this the best way to check for leaks http://vfaq.com/index-main.html ?
Old 06-30-2008, 11:53 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Boost leak. Follow the vfaq
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 07-01-2008, 11:39 PM
Gsst98's Avatar
Found out the problem I think its a head gasket white smoke comes out and it smells like crap. Im screwed basically. Anyone in the Cleveland area that would want to help me fix this, I just moved here and dont really know anyone.
Old 07-14-2008, 12:58 PM
pbGSX pbGSX is offline
you could replace it. might be a little work but its possible. i replaced the header to turbo gasket on mine and that took like 30 mins
Old 07-14-2008, 01:05 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Wow...
Headgaskets are nowhere as easy as a manifold gasket. Head gasket requires taking off the timing belt and resetting it properly, pulling the head, torquing the head bolts properly and a lot more. It's no walk in the park especially if you've never done it before.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
