| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
First Log!
Hey guys, though I got DSMlink actually in like a week ago I finally got the Keyspan serial to USB adapter today so I went out and took a couple logs.
![]() All I have to say is the DSMlink shit is bananas. I fuckin love it! I finally found out what my CEL was for it was a knock circuit problem. Needless to say I wont be doing too many crazy things without knowing how much I am knocking, but hopefully that stock tune shouldnt allow for much knock. Here is a link to the third log I took. It was a short 3rd gear pull followed by a coast. I started at about 2700 rpms and pulled through 4300. I was pretty excited to see IDC's only peak at 51% being that they are 450's and I have a 16g and FP2 cams. So, how do you other DSMlink guys think my log looks? I was wondering about shit. I didnt log everything I wanted and did log some stuff I wasnt too interested in, but I'll take a few more tonight. Here's some of my specific questions: My IAT's look rediculous. It was 79* F at time of log, but my IAT's were between like 100* F and 106* F the whole time. What are you guys with front mounts running relative to the ambient temp? It looks like the ECU is seeing a knock value under load, but it looks like it goes away when I was coasting. Is this just a default since there is a problem with the knock sensor? What the hell is going on with my o2 sensor? Its all the fuck over the place. How's everything else? So yeah, I figured that at 107.7 g/s airflow (peak as best as I could figure) translates to 14.2 lbs/min. Go me. I'll post another log a little later.
Re: First Log!
Sorry I can't help!!! Get the knock sensor fixed first then go from there. That may take care of some issues, especially if the ECU is pulling any timing due to that.
And my IATs were always higher when I was N/T than compared to the outside temp. Usually about 20 degrees IIRC. That was straight N/T with AC and everything near stock.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Re: First Log!
Well, I made a couple more logs today... like 14.
Most were just checking IAT's, coolant temps, and estimated milage but I did get a couple pulls too. I forgot how deep the gas pedal is since I've been trying to keep the throttle low until I could find out what kind of IDC's I was running. The first hard pull may have been WOT, but the second made it to like 3600 rpm before I realized I was only at about 80% throttle. The first pull went pretty good, I still didnt know how long I had before I ran out of injector, so I let off at 5158 rpm and sure as shit I was already at 83% IDC. It usually spikes to like 17-18psi at I think around 5500 rpm, so I dont think it was at the 10 psi I had it set at. I was flowing 171.2 g/sec, or right around 22.6 lbs/min. The estimated AFR went from like 9.8:1 at 3200 rpm to 9.41:1 at 5180 rpm so it appears to be running pig ass rich... but I wont trust that until I can snag a JAW. Oooh, one more question: is there a way to log TPS? I think it should be an easy enough thing to log, but I dont see where I can log it. My plan of action is to look at the knock sensor tomorrow and do a boost leak test tomorrow. I should have my FIC 1000's by the end of the week, so I am going to keep my WOT logs to a minimum until then. I'm not going to lie guys, making that pull was so much fun . Those cams really make that bitch scream, I love it! I am counting the hours until I can make a redline pull. Anyway, here's the screen shot of my hardest pull. Comments appreciated!
Re: First Log!
Your O2 sensor is working normal, you want to see it oscillating like that during closed loop operation (idle, part throttle cruising). Also, your knock sensor is dead so it goes into a limp mode and automatically retards the timing to save the engine just in case.
Sometimes my engine temps are around 123. It may be because i have an open air filter. I'd like to build a shroud to keep it down. You might want to look into that. BTW, the IAT is measured at the MAF which as you know is just after the air filter so actual temperature going into the engine is unknown to me. But i do know that after the post intercooler end tank is very cool as opposed to the inlet side. BoostEst only estimates 5 psi. Did you even go WOT? Also, you should get your fuel trims inline and MAF calibrated before you do any tuning. Go to www.jeffgst.com and find the MAF calibration page. Then post an idle and cruise log that shows LTFT Lo, Mid, and Hi. There is an "airflow" value that shows lbs/min.
Tim 1990 Talon AWD 2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink, PTE SCM5031
Re: First Log!
I'd like the actual file if you could post it!! At 10psi my engine is running 27 lbs/min on the 14b. Must be the stroker.
If you go to Display>values>and click on "airflow" look at the center and it will have a "props" button. You can switch it to lbs/min. Yeah you can log TPS, find and log the value "Throtpos". You can also find "TPSvolts" and adjust your TPS to .63v at closed throttle.
Re: First Log!
boy you sound excited lol but yes there is defenitely a way to log TPS you can also log tps volts if u feel so inclined. u have to make sure that the ECu is logging it then select it to be displayed. play with F4 and F7 between these you should be able to figure it out.
1995 GSX 2Gb bumper Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5 /Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs ![]() Wish list: CAMS |
Re: First Log!
Ok, here is that log. On that first log I dont think I actually went WOT, but I'm pretty sure on the last one I did.
I am sure that I should be flowing more, but I did stop at 5200 rpm's . The estimated boost on the second log is only 11 psi, but I dont know what it actually was. The things you said are going on the list to do tomorrow as well, and I will make another log afterward and check on shit. How's this log look?EDIT: I did find how I am supposed to find the TPS log, I didnt read as much as I should have before hand. Also, I completely spaced on the fact that IAT's are taken in the MAF. Tonight they were right around 100 at cruise, but got as high as 127 I believe when I was waiting at a light. This weekend hopefully I will get a shroud made up. EDIT #2: Tim, you said I should, "get my fuel trims in line" before tuning... what exactly do you mean by that? |
Re: First Log!
Do a search on fuel trims over at the dsmlink website. The user's guide that's out there for dsmlink also hes a procedure to get them inline. With stock injectors, i would assume they are good, but it's a good idea to check anyway.
Re: First Log!
Well, I figured out why my knock sensor wasnt working! The plug for the knock sensor was cut and I was plugging it into that other random plug next to it. Sooo, I hacked the knock sensor plug off of my extra harness, soldered the bitch on, plugged er in, turned the key to "on", and waited for a CEL. Never came. Plugged in the compy and went for a drive to see how it pulled when it wasnt seeing 3.2 degrees of knock. All I have to say is holy fuckin shit. The difference was almost night and day, especially in 1st and 2nd. Third was definately better, but not as impressive as 2nd. Quick question, so when a person is talking about a "count" of knock, are they talking about degrees of knock? (Thats the "Knock" value logged by DSMlink) Or are they talking about the "RawKnock" value?
So I took a few pulls to check it out. First real pull was in 3rd gear to 5144 rpm. Everything looked pretty good, but I thought the timing lookeda little off. I got .4 degrees of knock (the RawKnock value was 1) for like 150 rpms starting at about 3850, but that was the most I ever got. I got to 74.5% IDC on that pull and managed to log about 20.3 lbs/min. BoostEst was off quite a bit too. Anyway, here's the link. I took another pull after getting to another semi deserted road. I started logging partway through first gear and decided to get on it for second and third gear. I didnt even go WOT on it until about 4800 rpms, I was mostly watching the boost guage to see if I got boost creep or not. Sure enough I accidentally revved the bitch out to 6637 rpms. Why is that bad? 450's + FP2's + 16g = teh pwnage. I hit 100% IDC at 6500 rpms and when I hit my peak RPM at 6637 rpms I was at 102.7 IDC. After I revved that high I was a litte scared and just let 3rd gear hang. I guess I dodged a bullet on that one, where I did get .4 degrees knock from 6100-6260 (RawKnock value was 1) I was at like 94.9%-95.2% IDC there, I didnt get any knock when I got at or over 100% IDC. I did hit 28 lbs per minute too, so eat that Tim. Anyway, here's that log. The timing looked right on that last log, despite the knock.So what do you guys think? Anything look uber bad? I was going to try to get the MAF calibrated and get the fuel trims in line, but you need to do WOT pulls to redline which I obviously cant do. My FIC 1000's should be here like Monday so I am just going to wait to do any changes until then. I was also thinking that I should upgrade from the 1g MAF soon, when does it start to overrun? I kind of wanted to get a 2g MAF, but I know a guy I might be able to get a really cheap GM MAF and translator and I was thinking about going with a 3 bar GM MAP sensor too but I really need to do my research on that first. EDIT: So Thor feels like a moron. I started to look at the MAF calibration and saw that I needed to enter the elevation and shit. Sure enough default is 0ft elevation and I am at around 1350ft. I changed it and it was right up in the neighborhood of where it was supposed to be. I also see that VE is around 5000-5500 so I guess I will do it tomorrow. Tim, I search DSMlink forums to look for the fuel trim stuff, but didnt find much useful. I was looking at the jeffgst.com site's article on MAS/MAF calibration page. It looks like that is only for the 1200, 1600, 2000, and 2400 hz sliders. So I look at the top of the page and he has the link for "Fuel Trim Calibration Page." So I check that out and it went through the process of using the Lo, Mid, and Hi LTFT's and STFT to adjust the 50, 150, 250, and 400 hz. Is that what you were talking about? A simple yes or no is fine, I can search for the rest. Next questions... on the "Fuel Trim Calibration Page" for the 50 and 150 hz sliders it says to just rev to the 50 hz and 150 hz. Does that mean free revving while the car is stationary? What about the 250 and 400 hz sliders, for those it says to "cruise on the open road until a stable XXX hz." Does that mean pretty much any gear, any speed, any TPS, etc? Does the same go for the 800 hz slider?
![]() Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order. The Purple People Eater will ride again... January 2011 can't come soon enough. Last edited by Thor06; 07-04-2008 at 12:28 AM. |
Re: First Log!
Anyway .4 degrees of knock retard is nothing i would worry about. Most don't worry until a prolonged period of 2 degrees happens. I think a regular logger displays "counts". Not sure on that... Also, The VE table isn't active unless FAKE MAF is enabled. To keep it short, 99% of dsmlink users don't use it. It is used when you over run your MAF and you hit the switch over point. There is also plenty of this info on the dsmlink forum. Calibrating the MAF is easy doesn't require WOT. Here is what i do: First log LTFT Lo LTFT Mid I also log SelectedLTFT as it shows you what fuel trim the ECU is using. Fuel trims will only be updated when your coolant temp. is above 190F. LTFT lo will be seen at idle. Idle the car until you reach operating temperature and look at the LTFT lo. If it shows -3% then that means the ECU is pulling 3% of fuel to stay around 14.7 AF ratio. Open the AIRFLOW table and lower the 50 hz slider 3%. Do this for mid and hi and you should be all set. jefftgst.com shows how to calibrate the upper sliders where you do have to go WOT but I would wait on that until you get some bigger injectors. Timing is way high! I forsee knock problems when you increase the boost. I use the 2g timing map as of today that I also found on his website. Have you verified base timing yet? Here's mine from last night: http://www.uploading.com/files/3W694...008-2.dat.html
Re: First Log!
You can do it free revving or while driving. I feel better with the results while driving. When you make changes, take it back out and cruise with the MAFRaw around 150 and see where the LTFT mid settles. Try to get them a little on the positive side. Also, 1G ECU's will only take away a max of 4.7 on the negative side so it won't go lower than that.
If you increase boost with knock problems, look into this: http://www.dsmlink.com/wiki/2gtimingin1gecu I can't see you increasing boost since you are maxing out your injectors already.
Re: First Log!
Awesome. I will do that tomorrow along with the boost leak test (as long as its not too hot out) and getting the NLTS wire in.
Its good to know that the VE table is basically useless, I was a little scared of it. I also read the timing table on jeffgst.com and was pretty suprised... I was kind of under the impression DSM's took well to timing and I thought it was a good way to eek out more power, but from the sounds of it if anything you need to tone a 1g timing table down. Thanks for the help Tim! I'll get another log or two up tomorrow after I get the MAF dialed in. |
Re: First Log!
No problem. I forgot about logging LTFT Hi as well. Cruising at 65mph may be around the 250 hz slider, but I can't remember exactly.
Re: First Log!
Well, I just went out and did some logging. 50 hz was easy to log as that was like 1000 rpms. 150 hz was semi easy too, but 250 hz and 400 hz were both big pains in the ass.
I do have a question though, the STFT was bouncing all the fuck over. So what do I do? Take like an average of a few, or do I just find 50.0 hz on the tits and use that? I'll pick through my logs and post them up in a few minutes. EDIT: Ok, picked out the logs. Some are pretty long as I had a hard time getting the MAFRaw values just where I want them. Anyway, here they are: 50 hz, 150 hz, 250 hz, and 400 hz. *Cliff notes will be on the bottom, this all seems to have gotten really, REALLY long. Sorry, but thank you to anyone that decides to decipher my banter.* On the 50 hz log I got 50.0 hz at 3.53 seconds and my LTFT Lo is 9.8% and the STFT is 4.1% for a 50 hz slider value of 13.9% or rounded up to 14%. If you look at a different place on the log however, at say 1.05 seconds I hit 50.0 hz, but my LFFT Lo was 9.4% while my STFT was 5.9% for an adjustment of 15.3%. Is that 1% variance not really a big deal or what? Does that seem like a pretty big adjustment, or is that normal? My 150 hz log I got 149.8 hz at 5.98 seconds and both my LTFT Mid and STFT values were 4.9% for an adjustment of 9.8%. Later I got a 149.6 hz with a LTFT Mid at 4.9% but the STFT was 5.9 for an adjustment of 10.8%. I looked around and pretty much all the values within like 1 hz of 150 hz had adjustments of 10-11%. My 250 hz log is a long bastard. The LTFT Lo and LTFT Mid values always held pretty steady, but on the LTFT Hi it just read 0.0% for a while. Early in the log I found 249.7 hz with LTFT Hi of 0% and STFT 10.9%. Later, the LTFT Hi was just starting to move and I found another 249.7 hz with LTFT Hi of .2% and STFT of 9.2% for a total adjustment of 9.4%. Later yet in the log I had a nice long stretch of MAFRaw values of right around 250 hz and my LTFT had leveled off 2.9%. So I found a spot with 250.4 hz with a LTFT of 2.9% and a STFT of 4.1% for a total adjustment of 7.0%. I found another spot however, that was at 249.0 hz and had a LTFT of 2.9% still but a STFT of 5.5% for an adjustment of 8.4%. Thats a pretty big difference, but the 7% one was at the bottom of the cycling the STFT seems to do, the 8.4% was more in the middle. I found one later that was 250 hz right on the tits and it had a LTFT of 2.9% still but had a STFT of 6.1% for an adjustment of 9%. and that was also right in the middle of the STFT cycling. My 400 hz log was another really long one. I wont go as far in depth as I did in the 250 hz log, but I'll list a few of my adjustments at 400 +/- 1 hz and I will try to stay towards the middle of the cycling of the STFT. They are as follows: 8.2%, 7.4%, 8.2%, 8.4%. CLIFF NOTES: Well, I think in the process of writing the above book on my four logs today, I figured out what I was having trouble with. I was wondering what do do because of the cycling STFT, but I think I figured out that you just need to find a spot with close to the target MAFRaw value and a STFT value in the middle of the STFT cycling and use that, right? If that is the case, my adjustments will be as follows: 50 hz = 14% , 150 hz = 10% , 250 hz =10% , and 400 hz = 8%. I guess the way I see it is right now they are off by 8-14%, so if I go a degree high or low I can always just adjust it later. So, did I do it right? ![]() I am going to go out pretty quick here and take a WOT pull and see where I am at for the MAF calibration. What should I do about the 800 hz slider, do that one the same as the 400 hz sliders and below or the 1200 hz sliders and above?
![]() Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order. The Purple People Eater will ride again... January 2011 can't come soon enough. Last edited by Thor06; 07-04-2008 at 04:08 PM. |
Re: First Log!
You don't have to be at 50.0hz to use the 50 hz slider. If it said 75 hz then the 50hz would still be in effect. I don't know what the switch over point from 50 to 150 is. I think it's about 110.
Anyway, I would bump your 50hz slider up 10% and your 150hz up 5%. STFT will always be bouncing around and it looks to me normal as far as i can tell. Take your car back out for a spin afterwards and try to cruise and keep your MAFRaw around 150. Idle it for 5 minutes and see where the LTFT Lo is at. Like i said before, a percent or 2 positive is ideal. Have you seen this page yet? http://jeffgst.com/gmafcalibration2.html
