Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-30-2008, 02:08 PM
eclipse787 eclipse787 is offline
weird spinning noise 95 gs
when i start my car i hear spinning noises from where i believe to be when the tranny and engine bolt together. it sounds like when you spin a nut on a bolt and its loose and wobbles. hopefulley someone car understand what type of noise im trying to describe. i just rebuilt the motor 500 miles ago so i dont think its bearings in the motor. please help
Old 06-30-2008, 02:17 PM
Re: weird spinning noise 95 gs
ok. so i found ou twhen i pull in the clutch the noise stops. i have a new throw out bearing already so i doubt its that. or is it?
Old 06-30-2008, 03:01 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
My new clutch does that all the time, usually when cold, then goes away when warmed up. Did you install an aftermarket clutch?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-30-2008, 03:16 PM
no its a stock clutch. i just wanna make sure its not wrecking any gears.
Old 06-30-2008, 04:25 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Mine does this all the time, most aftermarket clutches make some noise, its just gear rattle. On a stock clutch you shouldn't get any noise but I guess its possible.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-01-2008, 09:47 AM
well maybe it is an aftermarket clutch. when i did my swap i figured i'd use the one from the junkyard untill it went bad then put my new one on. maybe the one i bought from the junk yard was aftermarket. thanks for the help...
