Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-30-2008, 01:06 PM
wreckdiver wreckdiver is offline
96 Cierra stalling problem
I have a 96 3.1 Cierra. After it warms up, and seems only when the temp outside is hot, it stalls while driving. First it goes to a rough idle, then it stalls. I shut the key off for about 15 seconds, then it starts back up and runs fine, untill it does it again. The hotter it is outside, the more it does it. I changed the fuel filter but no luck. I was told maybe the crank position censer or ignition module. Any thoughts?
Old 06-30-2008, 01:55 PM
maxwedge maxwedge is offline
A990 racer
Re: 96 Cierra stalling problem
Welcome to AF, you need to check fuel pressure and spark when this happens, then we can pin it down better.
