po300
When I first try to start my blazer, it will not start, then I spray the starter fluid in the carb. and it starts right up. I now have a code reader and its saying po300 which is random misfire ?? Does anyone know what this means or what I need to do to fix it ??
Any suggestions would really help!! Thanks |
Re: po300
What year and what engine?
Go easy on starter fluid. Carb cleaner is a lot safer. Code P0300 is a missfire someplace. If a 4.3 V6 With hard starting cold go for fuel presure check first. Low fuel pressure will cause hard starting and also missfires. The only true test on a fuel pump is to check the direct fuel pressure from fuel pump. A quick test is to block off the return line and see if fuel pressure comes up to 75-85 lbs. But do not run the pump at full pressure very long. Also when testing fuel pump and pressure you need to tape a gauge to outside windshield or outside mirror and drive it on the road for 20 -30 minutes until the pump gets has run a while to check for a pump fading out after hot. Hard to start cold or hot and fuel pressure testing guide lines. Check cold start fuel pressure. Check engine running fuel pressure. Check engine running on the road fuel pressure. Then shut it off and watch for fast leak down. Pinch off at rubber part or block off return line and check full pressure. If pump has full pressure with return line blocked and low pressure without it blocked most usually the fuel pressure regulator is leaking or not holding pressure. Later V6 and V8 gm engines should have 60-66 fuel pressure. Cold start should be 64-65 lbs of pressure. If you do not have full fuel pressure on a cold start the injectors will not squirt fuel. Do not leave home without it. Engine running should be 60-66 lbs pressure depending on engine load. Full pressure with return pinched off should be 75-85 or more. And if it has a fast leak down after shut off you have a leak in system. Post back fuel pressure readings.
