Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 06-29-2008, 10:42 PM
labmik labmik is offline
Plymouth neon 99- oil leak/ coolant leaks from water pump
Wonder whether My neon with 130,000 km worth repairing . have to change oil pan seal , and now coolant coming out from the water pump .
Can any body guide into how to replace the water pump and the oil pan seal
Old 06-30-2008, 09:33 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Plymouth neon 99- oil leak/ coolant leaks from water pump
Oil pan is easy, just drain the oil and take off all the bolts holding the pan on. You will have to remove the front motor mount because there is one oil pan bolt that hides behind it.
Try this how-to for the water pump...
http://jball.neons.org/howto/timing_belt/howto.html
2003 Dodge SRT-4
