Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 06-29-2008, 04:37 PM
lumberjak1984 lumberjak1984 is offline
wants to stall out/occasionally it does
only when i just about come to a complete stop this occurs. replaced the iac valve/new cold air intake/check engine light is still on with the airbag light as well. ny1 with some solutions. 2001 ls v8 103k.new alternator n battery,ac
drier is shot n the ac compressor manifold line. Could it b the cat converters, not gettin enough exaust flow?? old engine wear??
Old 06-29-2008, 06:26 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: wanrs to stall when stopping/occasionally it does
Please re-read the forum guidelines, particularly the section on posting ediquette (Any posts in all caps, and or funny mixed case such as "hey can u c thiz? L8r!" will not be tolerated).
That being said, have you checked the EGR system? Try pulling the diagnostic codes-if the Check Engine light is on, there are codes associated with it that may point you in the right direction. When's the last time the fuel filter was changed and a how often do you add fuel injector cleaner to the fuel tank?
-Rod
