Old 03-08-2003, 07:24 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
pm6 ?
what is the pm6 ecu, what car did it come out of ?
because the ecu that came with my ls motor says pm6
Team Lonely Drivers
Old 03-08-2003, 07:45 PM
plonger plonger is offline
1988-1991 Civic/CRX SOHC Si
Old 03-08-2003, 07:50 PM
anyone know if running the pm6 ecu with my ls is bad because thats the ecu the guy said he was running, so it must work but since its made for the sohc do you think its runnin lean or soemthign. idk could anything be wrong with running this on my ls
Team Lonely Drivers
Old 03-08-2003, 08:46 PM
91zc 91zc is offline
It will run an obd0 LS engine but the fuel and timing maps for the sohc are not optimal for the LS. I have always been a firm believer that you should run the proper ecu or something comparable rather than opting for the cheaper route of using an ecu that will not optimally run the engine. Just my 2 cents
91 civic 4dr
b16a
14.8@94
Old 03-08-2003, 09:33 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
agreed! the ecu can make all the difference...
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 03-08-2003, 09:54 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Yea, use the teg ECU.... chip it for better fuel maps if u have all the bolt ons........
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
