Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-29-2008, 01:40 PM
ABigWeaney ABigWeaney is offline
I need help on arp studs/bolts
What torque should i use on arp head studs, main studs, rod bolts? i looked at a lot of different places and could not find a good answer.
Old 06-29-2008, 01:50 PM
crash_1333 crash_1333 is offline
Exclamation Re: I need help on arp studs/bolts
Try this here are some specs let me no if this helps you any
PART NUMBER
(STRETCH INCHES)
FASTENER
TENSILE
STRENGTH
TORQUE
WITH
OIL 30 wt
TORQUE
WITH
ARP LUBE
Rod Bolts
BEB-08 220,000 PSI 65 ft lbs 45 ft lbs BEB-09 220,000 PSI 65 ft lbs 45 ft lbs BEB-1
(0.0065 - 0.007")
190,000 PSI 55 ft lbs 38 ft lbs BEB-12 190,000 PSI 60 ft lbs 40 ft lbs BEB-14 220,000 PSI 65 ft lbs 45 ft lbs BEB-15 220,000 PSI 65 ft lbs 45 ft lbs BEB-16
(0.0067- 0.0071")
190,000 PSI 48 ft lbs 30 ft lbs BEB-17
(0.005")
190,000 PSI 31 ft lbs 25 ft lbs BEB-18
(0.005")
190,000 PSI 44 ft lbs 31 ft lbs BEB-19 220,000 PSI 65 ft lbs 45 ft lbs BEB-20
(0.006")
220,000 PSI 65 ft lbs 50 ft lbs BEB-22
(0.0053 – 0.0057")
190,000 PSI Lube only 22 ft lbs BEB-24
(0.0052 - 0.0056")
190,000 PSI Lube only 24 ft lbs BEB-289
(0.006 - 0.0067")
190,000 PSI 48 ft lbs 30 ft lbs BEB-60
(0.0063" - 0.0067")
190,000 PSI 55 ft lbs 38 ft lbs BEB-6001
(0.0065 - 0.007")
190,000 PSI 60 ft lbs 40 ft lbs BEB-6003
(0.006 - 0.0067")
190,000 PSI 60 ft lbs 40 ft lbs BEB-RV60
(0.0055 - 0.0059")
Fly Wheel Bolts
FB1150 170,000 PSI 70 ft lbs 52 ft lbs FB1250 190,000 PSI 95 ft lbs 75 ft lbs FB900 190,000 PSI 60 ft lbs 40 ft lbs FB940 190,000 PSI 60 ft lbs 40 ft lbs FBB716 170,000 PSI 90 ft lbs 65 ft lbs FBT716 170,000 PSI 90 ft lbs 65 ft lbs FBV8716 170,000 PSI 90 ft lbs 65 ft lbs FBV985 - FBV944 190,000 PSI 85 ft lbs 63 ft lbs
Head Stud Kits
HSA11 Ê
rocker studs 5/16"
30 ft lbs
40 ft lbs
20 ft lbs
HSA11-B Ë
rocker studs 5/16"
30 ft lbs
40 ft lbs
20 ft lbs
HSA9
rocker studs 5/16"
30 ft lbs
40 ft lbs
20 ft lbs
HSAH3 190,000 PSI 80 ft lbs 63 ft lbs HSB42
rocker studs 5/16"
30 ft lbs
40 ft lbs
20 ft lbs
HSBM70 190,000 PSI 135 ft lbs 95 ft lbs HSC4201 190,000 PSI 85 ft lbs 70 ft lbs HSC4301 190,000 PSI 85 ft lbs 70 ft lbs HSC4601 190,000 PSI 85 ft lbs 70 ft lbs HCS48 190,000 PSI 85 ft lbs 70 ft lbs HSCB4601 190,000 PSI 85 ft lbs 70 ft lbs HSCSW53 190,000 PSI 135 ft lbs 95 ft lbs HSF38 190,000 PSI 130 ft lbs 90 ft lbs HSFX48 190,000 PSI 85 ft lbs 70 ft lbs HSGT6w 190,000 PSI 95 ft lbs 75 ft lbs HSL68 x 190,000 PSI 85 ft lbs 70 ft lbs HSMGC2 190,000 PSI 80 ft lbs 63 ft lbs HSP4201 190,000 PSI 135 ft lbs 95 ft lbs HSRV45 190,000 PSI 85 ft lbs 70 ft lbs HST425-10 190,000 PSI 65 ft lbs 45 ft lbs HST425-11 190,000 PSI 65 ft lbs 45 ft lbs
Main Stud Kits
MCS-1 190,000 PSI 85 ft lbs 70 ft lbs MS3B54 190,000 PSI 145 ft lbs 95 ft lbs MS5B54 190,000 PSI 145 ft lbs 95 ft lbs MSA33 190,000 PSI 95 ft lbs 75 ft lbs MSA44 190,000 PSI 95 ft lbs 75 ft lbs MSA54 190,000 PSI 95 ft lbs 75 ft lbs MSC5401 190,000 PSI 85 ft lbs 70 ft lbs MSC5601 190,000 PSI 85 ft lbs 70 ft lbs MSF375 190,000 PSI 85 ft lbs 70 ft lbs MSF40 190,000 PSI 85 ft lbs 70 ft lbs MSF54 190,000 PSI 135 ft lbs 95 ft lbs MSF64 190,000 PSI 135 ft lbs 95 ft lbs MSRV54 190,000 PSI 85 ft lbs 70 ft lbs MSSB560 190,000 PSI 85 ft lbs 70 ft lbs
Stainless Manifold/Thermostat Studs/Bolts
THS-1 (SS studs) 170,000 PSI 25 ft lbs 20 ft lbs THB-2 (SS bolts) 170,000 PSI 28 ft lbs 22 ft lbs AMS-1 (stainless) 170,000 PSI 30 ft lbs 20 ft lbs
here is the site also just copy and past the site in your search bar...
www.aptfast.com/ARP_Additional_Stuff/ARP_notes_info/arp_t_specs.htm - 37k -
