Old 06-29-2008, 02:54 AM
djwmtown djwmtown is offline
torque converter
I have an 03 grand am 2.2 auto. Can anyone tell me which plug on the tranny controls the torque converter for 4th gear?
Old 06-29-2008, 12:45 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: torque converter
Welcome to AF!!
Unfortunately, if you are looking to unplug the TCC solenoid you are out of luck. The 03 is computer controlled and you will be unable to unplug the solenoid. If you are having issues you need to take it to a mechanic with a trans capable scanner and have it scanned to see what is actually happening.
Old 07-01-2008, 11:57 PM
Well something is happening and for the life of me I cant figure out what it is. When I hit hard bumps when the car is in 4th it either dowshifts to third or the the tcc is "turning off"?? I mean I will go over some pretty rough road and the rpm's jump up like its downshifting. Does any one have any ideas? Something has to be loose but what could it be?
Old 07-03-2008, 03:44 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I've got a couple questions.
Are you at a speed where it's getting close to where it would normally downshift (or unlock the TCC)?
Is the road rough enough that your foot boucnes and presses the gas enough to make it downshift?
Also, if available, drive down that road with a scan tool while watching the knock sensor in the datastream. If it's seeing the road bumps as engine knocking, it may unlock the TCC or downshift to reduce the load on the engine.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-04-2008, 12:41 AM
Speed is not really a factor. I mean it's anywhere about 40mph and up (shifts into 4th about 40mph). Someone told me there's a sensor or something attatched to the brake pedal under the dash that works to unlock the tcc when braking. I'm gonna check that out.
Old 07-06-2008, 03:25 PM
J-Ri's Avatar
That is correct. Again, a scan tool would make it quicker, in the datastream there should be a BOO (Brake On/Off) parameter. If the value changes to on, it's probably the switch. Check a wiring diagram first, but I think that it goes off the cruise control brake switch, in which case see if cruise cancels when you hit this section of road.
The only other possibility is off the brake light switch, if so, just have someone follow behind you and see if the lights come on.
Old 07-07-2008, 01:43 AM
Could it be possible that it's in fact going into third? Is there anything that could possibly cause it to go into third during a decent "jolt"? I'm just trying to explore all possibilities.
Old 07-07-2008, 03:30 PM
J-Ri's Avatar
It sure could be, try manually shifting into 3rd when the rpm goes up. If it stays the same, it's downshifting, if it goes higher, just the TCC is unlocking.
You could check for a leaking MAP hose, if the hose is cracked it could be leaking when it's bounciung around and the computer is seeing a higher engine load and commanding 3rd gear
Old 07-08-2008, 01:03 AM
I'm not sure where the MAP hose is.I will find out and check it out. Is there anything else it could be besides that?
Old 07-09-2008, 03:40 PM
J-Ri's Avatar
There's 3 or 4 hoses on the throttle body, those aren't it, it is actually on the plastic intake manifold with some plastic tabs around it, then the hose curves off to the right (as you see it standing in fron of the car). I'll take a pic of mine, it's right up front, 20 seconds to replace including cutting a new section of hose.
There's always something else it could be, that might be the end of what I can give you, but I will think on it.
Old 07-09-2008, 11:34 PM
cool thanks for the help.
