Old 06-28-2008, 09:59 PM
Protege v2.5's Avatar
Protege v2.5 Protege v2.5 is offline
Diagnosing a brake problem
right forum?
Well I was putting new brake on yesterday and today. Finished the Job and went to start the car. Pumped the brakes to build pressure in the system. All is well pressure is back in the pedal and then I here a pop. Pedal goes 90 percent of the way to floor. Fuck me. Turned the car off, checked under the hood and look at the master cylnder, fluid everywhere. Looks like all the fluid came out between the master cylinder and the power brake unit. Also the passenger rear SS brake line popped. Fixed that bled the the brakes. Brake pedal is nice and firm again. Turn on the car pedal goes almost to the floor again. And I get a nice sucking sound coming from the problem area.
Any Ideas.
Old 06-28-2008, 10:14 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Diagnosing a brake problem
if you have fluid leaking out between the master and the booster, the master is bad
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 06-29-2008, 05:35 AM
Well the fluid no longer leaks, but does that a make difference? Also what would cause this to happen? Anyway to prevent it?
Old 06-29-2008, 07:42 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Sounds to me like the brake line wasn't connected properly or was cross-threaded. When the power assist was working, the pressure built up by the brake booster forced the line off and put a whole bunch of air in the system. I'm guessing you didn't get all the air out of the system since you don't have leaks currently. You may also want to remove the brake line and closely inspect the threads for signs of prior cross-threading. You don't want the line to pop off while panic stopping on the highway.
Was the master cylinder off for any reason recently?
-Rod
Old 06-29-2008, 08:37 AM
AF -Advisor
not really. Once a seal is shot, its shot
Old 06-29-2008, 11:48 AM
well i know why the line popped. it had been rubbing against the body. and it popped mid line . I hadnt touched the lines before everything popped. Somehow there must been an excessive amount of pressure in the system.
The MC and Brakeline went at the same time.
I all did was pump the breaks to put pressure back into the system. Then pop.
Old 06-29-2008, 06:35 PM
shorod's Avatar
SHO No Mo
Ahh, okay, the line physically popped. I read the original comment to be that the line popped off, thinking it was the where the threaded fitting attaches to the master cylinder.
-Rod
Old 06-29-2008, 06:44 PM
I'm just glad this happened in the Driveway and not on the highway.
