Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 06-28-2008, 06:55 PM
virgamanda virgamanda is offline
Send a message via AIM to virgamanda
06 Sonata 3.3 PO504 Help
I have an 06 Sonata with the 3.3 engine with 26000 miles and the check engine light is on. It runs fine and everything seems ok. I had it checked and it reads PO504, a brake switch A and B correlation issue. what could cause this and are there any recalls or tsb on this issue. any help is greatly appreciated.
Old 06-29-2008, 07:44 AM
Bear Bear is offline
Re: 06 Sonata 3.3 PO504 Help
Go to http://sonata.jerrystout.us/ and under misc and DIY you will find OBDII codes, however, I did not see your code listed.
Old 06-29-2008, 05:48 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Could be a couple things. . . Bad Stop fuse, short in stop light switch signal circuit, Stop light switch, or a problem with the ECM
