Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 06-28-2008, 06:54 PM   #1
Bobbywolf
Hood from a sohc fit a dohc?
I have a 98 dohc neon with a huge crease across the hood from the previous owner. The local wrecking yard only has a couple dohc hoods, and they are in bad shape, but many sohc hoods. If I were to remove the intake plastic that goes over the engine, would I be able to get away with the sohc hood? It would be great if I could, because the rest of the car is mint, with a really farked hood. Little too gheto for me.
Rob
Bobbywolf is offline   Reply With Quote
Old 06-30-2008, 09:28 AM   #2
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Hood from a sohc fit a dohc?
It will fit, but you will need to cut out some of the bracing to get it to fit correctly.
The bulge is there to clear the cam cover on the DOHC.
2003 Dodge SRT-4
das2123 is offline   Reply With Quote
Old 07-26-2009, 11:04 PM   #3
butman_33
Try looking for a plymouty neon expresso....even the SOHC's came with the Power Bulge hood.
butman_33 is offline   Reply With Quote
Old 08-05-2009, 10:56 AM   #4
HPNOTIQracing
im sure he didnt walk around looking at the motor to dictate if it was the right hood.
im sure he just looked at every hood and seen which were dohc and which were sohc.
as das said cut the bracing over the timing cover area
HPNOTIQracing is offline   Reply With Quote
