Old 06-28-2008, 02:40 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
How to replace Ingnition Switch 1990 C2500
I have a 1990 C2500 with the 5.7l. I need to replace the key switch, it is an automatic with till steering. Anyone have any tips or advise? Does not seem to be too hard.
Old 06-28-2008, 03:14 PM
rhandwor rhandwor is offline
Re: How to replace Ingnition Switch 1990 C2500
You need to pull the steering wheel if it has an air bag it will take a special socket for this. Some of the newer units have a different setup. Go to
http://www.alldata.com/ and buy a years subscription or buy a service manual on ebay. Always pull the battery negative the night before and the airbag fuse. You will need a wheel puller and a lockplate removal tool. You can check Haynes but have directions. AutoZone and Advance have a tool loaner program.
http://www.matcotools.com/ will sell any tools.
If you buy alldata always print electrical diagrams before it expires and anything else you want.
Old 06-28-2008, 03:34 PM
broughy84's Avatar
broughy84 broughy84 is offline
Okay, disconnect the battery, set the parking brake, put the key in run, pry the horn button off, unplug the horn. Remove the snap ring from the shaft, remove the nut off the shaft. I think it's an 18mm. Get your steering wheel puller or harmonic balance puller out and pull the wheel off. Pull the black plastic cover off, use the lock plate removal tool to depress the plate, pull the ring off the shaft that hold it on and remove. Unscrew the turn signal lever from the switch, unscrew the switch and remove ( you don't have to unplug it, just give it a tug and pull it over the shaft. Unscrew the screw holding the tumbler in and slide it out. The switch must be in RUN. Installing it is the reverse.
It really pretty easy to do, I can do it in my truck in about 15 minutes now. I have changed three of these in mine and a couple of the trucks at work when they purchased them. (All our trucks are keyed alike) I Can't stress enough DO NOT DROP THE SCREWS IN THE BOTTOM OF THE COLUMN THIS WILL REQUIRE COMPLETE DIS ASSEMBLY IF YOU DO.
BTW I think all the screws at T10's or T15's.
Good Luck
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 06-30-2008, 07:50 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Is there an easy way to remove the ring that keeps the lock plate in place on the shaft? IIRC many years ago doing this, it was a real pain in the a$$ getting the ring off.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 06-30-2008, 08:13 PM
This is a picture of the tool http://www.autopart.com/TOOLS/TOOLSMAIN/Tool/T_1504.htm
It is possible without a tool but hard. Most tools have two bolts but this must have both in one.
Old 07-05-2008, 06:58 AM
scuba4321's Avatar
Thanks for the advise
