Go Back   Automotive Forums Car Chat > Suzuki > Swift
Old 06-28-2008, 07:14 AM
Shearer9 Shearer9 is offline
Unhappy Swift main headlight problem
I have a 1998 suzuki swift. When I turn on the dipped headlights both lights work fine. When I then switch to main beam, the passenger side goes to main, but the drivers side remains on dipped. I have changed the bulb but still have the same problem. Can you help?
Thank You
Old 09-03-2008, 10:37 PM
doug2060 doug2060 is offline
Re: Swift main headlight problem
Check the wires on the connector that the light plugs in to. Clean it out real good with carb cleaner or better yet rubbing alcohol so you don't risk melting wires and make sure the wires going in are connected. Good luck...
Old 08-15-2009, 11:12 PM
reylots reylots is offline
Hi, i have a suzuki swift 2000 and my headlight wont turn off. even if i turn off the engine the high beam indicator on the dash board is still on. dont know if there's a loose connection somewhere. please help me and thanks in advance.
