Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 06-27-2008, 06:36 PM
jasom jasom is offline
Adding seafoam to your motor oil
Has anyone done this and if so were there good results? I did some reading on it and it say add it to your oil an hour before oil change. I just want to know if this stuff could be to harsh on a high mileage motor? Also this is gasoline not diesel.
It also says to add 1pint to 4 gallons so it looks like I only add about 6oz to 5qts of oil.
Old 06-27-2008, 07:56 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Adding seafoam to your motor oil
No No No no way man.
Not of you want you engine to live to a ripe old age.
MT
MT
Old 06-27-2008, 09:16 PM
MT
Ok just seeing what anyone had to say on this subject. Thx for the reply.
Old 06-27-2008, 09:21 PM
Blue Bowtie's Avatar
Registered Offender
I'll second that. There are already plenty of contaminants in your engine oil, so why add more?
Old 06-27-2008, 09:55 PM
I was just looking for something to clean up any carbon build up and anything else that needed a little cleaning internaly. It's a 5.7 with 175,000 in a 1997 tahoe.
Old 06-28-2008, 09:20 AM
MT-2500's Avatar
AF - Advisor
New fresh good oil and a good filter change ever so often is the only good additive.
If you get to fooling around with the carbon and sludge it will wind up in your oil pump and crank oiling holes and good by engine and crankshaft and rod and main bearings and lifters.
MT
MT
Old 06-28-2008, 01:54 PM
SLJ2137694 SLJ2137694 is offline
Regular use of Top Tier Gas will clean things up nicely. Intake carbon deposits and fuel system will be kept much cleaner. This won't do much for a sludged up engine though. I have seen it clean intake valve deposits and has helped clean combustion chamber deposits. http://toptiergas.com/
Retired and Loving It!!! 33 years with General Motors Product Service Engineering. A.S.E. Certified. You can fix ignorant but stupid will be a real challenge!
Old 07-06-2008, 06:51 PM
Registered Offender
Try polyalphaolefin in the crankcase to clean up sludge and varnish deposits.
Old 08-03-2008, 01:11 PM
RainRider RainRider is offline
Added the "toptiergas" site to my favorites.
Was surprised to see Mobile not on it.
Fortunately, Chevron, Shell, and Texaco have been my gasolines of choice for years now (in that order)
