Old 06-27-2008, 08:58 AM
janositamas's Avatar
janositamas janositamas is offline
Masking tape residue
Hi Guys, I have a problem with my Tamiya masking tape: after peeling it off (after masking & painting) it always leaves some residue on the area I masked off. What do you guys do to avoid it? Or what am I doing wrong? Thanks, any help appreciated.
Old 06-27-2008, 09:07 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Masking tape residue
What type of paint are you using it on?
PHOTOBUCKET SUCKS
Old 06-28-2008, 12:45 AM
Dupli Color car paint.
Old 06-28-2008, 05:10 AM
malscar's Avatar
malscar malscar is offline
Are you allowing the first colour you lay down to not only properly dry, but harden before you tape the area?
Must admit I am surprised you are having a problem with the Tamiya tape.
Old 06-28-2008, 08:01 AM
MPWR's Avatar
Which is what- lacquer, enamel?
I've never seen residue left behind by Tamiya tape. But it can cause problems if it (or any other tape) is applied over a painted surface that hasn't had time to fully cure/outgas. If tape is applied over outgassing paint for more than an hour or so, the tape will trap the solvents in, keeping the paint soft. When you peel the tape up later, it almost looks like the tape adhesive was attacking the paint.
To avoid it, give the paint plenty of time to outgas before masking, and don't leave the masking on any longer than absolutely necessary (an hour or two at the most).
PHOTOBUCKET SUCKS
Old 06-28-2008, 05:16 PM
paparadiation paparadiation is offline
janositamas, i probably can understand what u mean, actually i masked a windshield with tamiya tape and had some residue remaining after i took the mask off. No harm done, i cleaned it up with Micro-Gloss (form the Micro mesh set) but i guess tamiya fine compound would do fine as well. The trick is , before applying the masking tape on the kit, put it on your hand or even forehead, to get rid off most of the glue (my forehead seems to be very greezy )
Old 06-29-2008, 02:04 AM
I used it after the 1st paint has dried, about 5 days after painting, that's why I was surprised I had residue marks. As for the problem, I think I know now what it was: I think I left the masking tape on the body for too long (from what MPWR wrote) as I put it on the night before painting, and get rid of it 2 hours after the paint. So it was on for about 24 hrs.
Thanks guys for the help! I will try to avoid leaving the masking tape on for this long in the future!
Old 06-29-2008, 03:32 AM
cyberkid's Avatar
cyberkid cyberkid is offline
That's strange, I've left Tami tape on for weeks without it leaving any residue. And I don't prestick the tape to anything before applying.
I've also left it on all types of paint too... even put the taped item into my dehydrator for weeks on end....
Is your roll of tape old? Like a couple years old?
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 06-30-2008, 01:27 AM
No, it is almost brand new, I bought it about 3 months ago!
Old 06-30-2008, 07:23 AM
jmesawitz's Avatar
jmesawitz jmesawitz is offline
janositamas,
If nothing else, you are not alone. It has happened to me more than once and is seems to occur more often on metalic colors rather than solids. The last time it bit me was with Tamiya rattle can paint that had a week between spray and mask. To me it looked more like the tape removed the surface sheen from the paint rather than leaving a residue. The end result is that you can see every where the tape was applied with edge pattern, crease detail etc. No cure other than to strip & re-paint for me. On my next attempt, I clear coated between color and masking for the second color.
Wish I knew why it was a problem in the first place.
Old 06-30-2008, 08:16 AM
Originally Posted by jmesawitz
janositamas,
Thanks, I will give it a shot next time so I will clearcoat first between the 2 coats and apply the masking tape onto the clear. Time will show.
Old 06-30-2008, 08:36 AM
MPWR's Avatar
You're description is exactly what happens when outgassing solvents are trapped by masking tape.
Tape residue can almost always be quickly and easily polished off. If polishing compound doesn't do the trick, residue is likely not your problem.
PHOTOBUCKET SUCKS
Old 06-30-2008, 09:33 AM
Thanks MPWR, I give it a shot with Tamiya Polishing Compound!
Old 07-01-2008, 05:22 PM
off the edge's Avatar
off the edge off the edge is offline
I think I know exactly what the problem is because this happens to me alot because i paint alot of xbox 360s. The residue is due to the heat from the outdoors or just about anywhere hot. Say you just finish painting whatever it is let it set for a while then put it outside above 80 degrees for 5 to a billion minutes it will happen. masking tape hates the heat. It really isn't a problem use some thinner or rub your finger against it should come off. Another problem with masking tape is that if you havent let the paint dry for more than what a day or two and put it on 3hrs, 5,hrs or any earlier the tape will leave an imprint of itself. if you ever noticed on the adhesive part of the tape there is a texture.
Old 07-03-2008, 09:00 PM
Sixx Sixx is offline
I agree with MPWR as far as getting the tape off as soon as possible to avoid both situations, ghost tape lines and trapping solvents.
I mostly have a problem with BMF leaving residue and have yet to solve the problem of COMPLETELY removing this type of residue, any suggestions would be great!
