Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-27-2008, 03:56 AM
alaskagoldman alaskagoldman is offline
1998 Grand Cherokee Laredo P0171 code
I have a 1998 Grand Cherokee Laredo. I suddenly noticed that the engine was running rough and my fuel mileage dropped by about a third. BLACK smoke shoots out the exhaust when I accelerate. Runs better at high RPMs than low ones. I will manually shift my auto transmission because it runs better with higher RPM shift points. I have changed plugs, wires, dist cap and rotor. Plugs were BLACK and carbon fouled. Problem remains and Check engine light is on and trouble code still reads P0171.
I am constantly looking for a vacuum leak because the code is detecting a lean fuel mixture and pumps too much fuel in to try to compensate.
The engine is 4.0 L straight 6 with automatic transmission. I listened to the fuel pump underneath the car when it was running. High pitch whine coming from inside the fuel tank. Any ideas will be appreciated.
Oh, I have also purchased a new Oxygen sensor but have not installed it yet. Was hoping that maybe this might help out. I did remove the current one, the one before the catylitic converter and cleaned all the carbon off of it.
HELP! I can't afford to only get 150 miles to a tank of gas when it costs 90 dollars to fill it these days.
most recent maintenance BEFORE the problem started was i replaced a worn serpentine belt.
Old 06-27-2008, 05:29 AM
reekor reekor is offline
Re: 1998 Grand Cherokee Laredo P0171 code
Check your fuel pressure with engine at idle should be around 50PSI. With engine and pump off should hold above 30psi for 5 minutes.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 06-29-2008, 12:01 PM
ken729 ken729 is offline
I had exact same problem with my 1996 Laredo about 3 weeks ago. It was the pre cat o2 sensor that failed.
Old 07-01-2008, 09:55 PM
I changed the O2 Sensor, problem persists... looks like I'll have to check the fuel system for sure. I just hate the idea of taking the fuel tank off the car.
Old 07-02-2008, 03:26 PM
I spoke before I checked the code reader! The P0171 code is gone and is now replaced with a new code.
The new code is a misfire in cylinder 5. So I will now investigate that. My gas mileage is much better now with the replacement of the 02 sensor. I can actually feel the miss in the engine now though.
Old 07-07-2008, 12:02 PM
Had a carbon fouled plug on number 5 that occurred when the O2 sensor was bad and the engine was running rich. Cleaned the plug and Everything is Perfect! I'm getting better gas mileage now than I ever have since I have been the owner of this jeep.
I hope this experience of mine being posted here helps the next person out.
Thanks to those that responded to my request for suggestions.
Old 05-03-2012, 06:52 PM
Funcamper3969 Funcamper3969 is offline
I also have this code, with the similar problems. Mine is actually better in lower gears. I have the rich black smoke, in the exhaust as well as the plugs. I have the P0171 code. It sounds like more gas then less. I changed the plugs, cap and rotor as well as the plug wires. I was thinking of the fuel/air sensor? Any suggestions?
