Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 06-26-2008, 04:05 PM
troubles789 troubles789 is offline
02 I-6 oil filter type and radiator cap?
I just bought the 02 XL with a 4.2 I-6 and in the owners manual I can only find the specs for the 6.6 8 cyl, P58 and 7 quarts of oil.
What oil filter does the 4.2 6 take? and how many quarts of oil does it take with filter changed?
Here is my stupid question for the day. When I try and remove the radiator cap it goes loose like it is coming off then re-tightens up, I was scared to keep twisting as I didn't want to break something. Whats the trick?
Old 06-26-2008, 06:58 PM
maxwedge maxwedge is offline
A990 racer
Re: 02 I-6 oil filter type and radiator cap?
7 qts, the GM filter is P-61. Keep turning it and lift up at the same time, cold of course. Funny there is no 8 cyl. Envoy in 2002, sounds like the wrong year book?
Old 06-26-2008, 07:29 PM
Book says right on the cover 2002 Envoy / Envoy XL.
Old 06-26-2008, 07:33 PM
A990 racer
May be a late owner's manual in contemplation of the 2003, as there is no listing for a 8 cylinder 2002 Envoy. But you have your info either way.
Old 06-26-2008, 07:44 PM
It was my bad reading that read into 6.6L as a engine size instead of oil amounts. It is not 6.6 V-8 it meant 6.6L of oil = 7 qts. My bad on learning this vehicle.
Thanks for making me go re read it again.
Old 06-26-2008, 07:45 PM
A990 racer
Thumbs up Re: 02 I-6 oil filter type and radiator cap?
Thought so, just didn't want to insult you, you're on your way.
Old 06-27-2008, 10:51 AM
Any idea whats going on with the rad cap?
Dont worry about insulting me, I would rather learn the vehicle and have the right info, then to understand what I read wrong.
Whats the difference in PF-58 and the P-61 oil filters?
The owners book shows a 58 and online parts order shows a 61 as you stated.
Old 06-27-2008, 03:02 PM
A990 racer
61 is an updated version, no more 58's, the rad cap is a pita just keep turn it counter clockwise and pull up at the same time, it is a tight fit.
Old 06-28-2008, 10:04 AM
Finally got the rad cap off.
All is well and man these new ones ride smooth, 2002-.
Owned 91 S10 blazer and 93 S15 jimmy and Dad has a 2000 blazer to compare to.
Old 06-28-2008, 03:23 PM
A990 racer
Same here, my wife had a 92 S10, no comparison in ride and quality.
Old 07-04-2008, 11:10 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I've got an '03 XL 4wd and compared to the '96 Jimmy 4x4 I had, the Envoy floats alot more. The suspension is very soft. But the wife likes it and I don't drive it, so I'm fine. Has decent pep though for a V6...actaully has more HP than the Jimmy's V6...just taller & heavier. Good truck though.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
