Old 06-26-2008, 07:38 AM
Dumpy2's Avatar
Dumpy2 Dumpy2 is offline
Send a message via MSN to Dumpy2
low rpm shake
I drive a 95 accord ex. It shakes at low rpms, around 1800 - 2000. It use to only do it when it was under load (driving down the road) but now it does it a little when it is parked or in neutral as well. It isn't a really bad shake usually, but you can feel it. If you hit just the right rpm though, it will shake pretty severely.
I just did a tune up, involving new:
-plugs & wires
-distributor cap & rotor
-fuel filter
-intake
-exhaust
-valve cover gasket
Got everything put back together and the shake is still there. I have pretty much done everything my skill allows to try and remedy the problem. I am just trying to get an idea of what it might be, so I know how much I am going to have to shell out at a shop.
Thanks in advance for any wisdom you could share.
Old 06-26-2008, 10:39 AM
somick's Avatar
somick somick is offline
Re: low rpm shake
Make sure your coolant is up to the level.
Bleed the possible air pockets.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 06-26-2008, 01:23 PM
Dumpy2's Avatar
Re: low rpm shake
bleed possible air pockets out of the coolant lines? I just had my radiator flushed and filled over the winter. I would imagine that it should be fine. Any other ideas????
Old 06-26-2008, 04:35 PM
StealthSnake36 StealthSnake36 is offline
Re: low rpm shake
check the motor mounts make sure theyre not cracked
Old 06-26-2008, 05:24 PM
lamehonda's Avatar
lamehonda lamehonda is offline
Re: low rpm shake
If your mounts are bad, the motor will most likely shake if you are in drive and not moving. you might not notice this as much with a standard tranny.
1987 Honda Accord LX-Dead
1999 Honda Accord EX-L 5 sp-Sold
2006 Subaru WRX Wagon 5sp-Sold
2005 Nissan Frontier ext cab 4x4 4.0L-Sold
2006 Kawasaki Ninja 500r-Sold
2004 Yamaha FZ1 Silver/Black- Sold
2008 Mazdaspeed 3-In the driveway
Old 08-11-2008, 08:40 PM
bpolley bpolley is offline
Re: low rpm shake
I have the same issue with my 92 Accord. Check the mounts carefully. I found my front torque mount is crack. It is $42 at Advance Auto. Not to difficult to change out either. Good luck
