Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-25-2008, 10:38 PM
baron85 baron85 is offline
93 Camaro 3.4 rough idling
I have a 93 Camaro with the 3.4 it started to idle rough and and misfire when I gave it gas. I have changed plugs the DIS the fuel filter but the problem is still there, there is no codes so when I scan it nothing shows up. I also changed the wires and no better results I read in forum something about some wires on the left side head that break over the years. Does that sound familiar to anyone? Thanks
Old 06-26-2008, 02:31 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: 93 Camaro 3.4 rough idling
i thinking those wires that break are the engine ground straps. strong possibility you have injector problems. just a thought tho.
Old 06-26-2008, 09:47 AM
Blaiser17 Blaiser17 is offline
Send a message via AIM to Blaiser17
Yea, sounds like it is fuel related. Check fuel pressure then check your injectors.
"Here are a list of some of the symptoms you may be having caused by poor fuel distribution by faulty fuel injectors.
(1 Hard Starting
(2 Poor fuel economy
(3 Rough Idle
(4 Car runs fine when cold and terrible when warm
(5 Car will start just fine when cold and not when warm
(6 Getting a fuel smell inside the car
(7 Loss of power in acceleration
(8 Fuel leaking from injector seals or injector
Injectors are just as easy to replace as your spark plugs. "
1999 Chevy Monte Carlo 3.1L
1991 Chevy Camaro 3.1L
1981 Chevy Camaro z28 383 Stroker
2000 Mercury Cougar v6
