Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 06-25-2008, 06:20 PM
Toolman56 Toolman56 is offline
Were is Vin
I have a 1964 plymouth valiant, need to know were the vin number is located on this car to get plates and inspection going, thank's
Old 06-27-2008, 12:34 PM
KManiac's Avatar
KManiac KManiac is offline
Re: Were is Vin
The VIN is embossed on a stainless steel plate, which is either spot-welded or rivitted to the door frame inside the driver door, near the dome light pin switch. It is a ten-digit number. The first two digits are stamped from the top and the last eight digits are embossed from the bottom.
Your car should also have a Body Data Code plate under the hood, on the inside fender panel, on the driver's side of the engine compartment. On the bottom line of this plate, you will see a three-digit number under the heading BDY. The first two digits of this number should match the first two digits of the VIN, the digits stamped from the top.
Let us know what you find.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
