Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 06-25-2008, 12:58 PM
beegolden beegolden is offline
2000 Cougar 2.5 Power Steering Pump
Just a question on the power steering pump, how long does it take to change? any special tools?
Thank you
David
Old 02-22-2009, 07:18 PM
Terry_Lee Terry_Lee is offline
Re: 2000 Cougar 2.5 Power Steering Pump
I just took one off. you'll have to support the engine with a jack and remove the motor mount. Loosen the four bolts holding on the pulley. Then using a 3/8 drive break over you will need to take the belt off the ps pulley. Remove the pulley. Then it's most 10mm bolts and nuts. Be careful though I stripped three of them and had to beat two off with a screwdriver and hammer.
