Old 06-25-2008, 10:33 AM
pnut333 pnut333 is offline
Strange problem - lack of power 30 seconds after startup
My truck is a 1998 3/4 ton Chevy crew cab short bed, with 5.7 engine, 4x4. I have new plugs, wires, cap, rotor, and air filter. No major repairs ever. 140,000 miles. Problem same vehicle hot or cold.
30 seconds to 1 minute after I start up the truck when I try to accelerate, it bogs down significantly, it can barely keep going, let alone accelerate. After about 15-25 seconds, it goes away, and I can drive and accelerate like normal. It feels almost like the truck is not getting enought gas.
IF I push the pedal way down when it has this problem, it will sputter and pop significantly, the problem lasts longer. It goes away more quickly if I let off the gas and slowly, barely give gas.
The problem was exactly the same before and after fuel pump replacement. Has been happening since 50,000 miles. Seems like it's getting a bit worse, but can't be sure.
Any ideas? It feels like it's just not getting any fuel during that startup drive. If I sit in the parking lot for 2 mins, then go, It does not do it.
Old 06-25-2008, 09:16 PM
777stickman 777stickman is offline
Re: Strange problem - lack of power 30 seconds after startup
My 1st thought is the CTS (Coolant Temp Sensor). Need to get an engine capable scanner on it and see what it's reading. Any codes stored to help us out??
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-26-2008, 08:03 AM
Nope, it is not throwing any codes at all.
Do you think the Coolant would warm up enough in those 30 seconds to make the difference with the sensor?
Old 06-26-2008, 01:29 PM
2000CAYukon 2000CAYukon is offline
What is the fuel pressure at startup and for 30 seconds after startup?
//2000CAYukon
