Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-24-2008, 10:52 PM
92talontsiawd 92talontsiawd is offline
Send a message via AIM to 92talontsiawd
CEL runs rich
ok so just today my check engine light came on and is now running richer then it should. and there is NO boost leak, and my step dad asked if my pcv valve was clogged but would that cause the rich running and the check engine light? if not what could cause it? i have NOT scanned it because i cant find anyone with the adapters for the scanner.
Old 06-24-2008, 11:58 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: CEL runs rich
Step 1. Go to Autozone, Napa, Checker, Advance, or where ever parts are sold and buy a Haynes manual.
Step 2. Find Chapter 6.
Step 3. Do it.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-25-2008, 09:25 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: CEL runs rich
Did you leak test the car, or are you guessing?
Make friends with someone who owns a logger, or pick one up.
Kris
2012 Genesis Coupe 2.0t
Old 06-25-2008, 05:27 PM
Re: CEL runs rich
well i had a boost leak, and i fixed it. but now it will run rich as shit, and then if i shut the car off sometimes it will run fine and sometimes it wont. and the cel stays on and i already have a manual i just havent looked
Old 06-25-2008, 06:16 PM
Thor06's Avatar
Jizzed In My Pants
Re: CEL runs rich
If you have a manual (which tells you how to pull codes), why wouldnt you just do it and get it over with rather than have us play the guessing game? It'll take you all of about 5 minutes and it will tell you exactly why that code is being thrown.
Old 06-26-2008, 06:41 AM
Re: CEL runs rich
Wait, wait, wait...didn't you buy a logger?
Kris
Old 06-27-2008, 11:45 AM
Re: CEL runs rich
no i do not have a logger. and i did the manual code reading and found out that the BARO sensor insnt working correctly. so i went and bought a new air metering assembly and it still didnt fix the problem. so i did the tests in the haynes manual and come to find out that the sensor is getting signal power, but the assembly is not getting battery power. and the book doesnt say what to do, any ideas?
Old 06-27-2008, 11:53 AM
Re: CEL runs rich
Got me there, and sorry for the name confusion. A member with a similar name recent purchased a logging device.
Kris
Old 06-27-2008, 03:39 PM
Re: CEL runs rich
ok forget about my previous statement. i brought the car into work and i cleared out the codes and then ran the car again and two codes come back. code 13, and 25. for the intake air temp sensor and the baro sensor. and i already replaced both of them because they are in with the air meter assembly. also i checked the plug and all the othe tests for the sensor. and every test i did came out good. heres alittle info when this all happened. the car was running fine, i live in mass. i drove to mount washington in new hampshere and the day after i got back the car started running like complete crap. but i replaced the sensors and everything checks out fine. but still the same codes come up for the baro and IAT sensor. if anyone can help me it would be great. thank you
Old 06-27-2008, 09:23 PM
Re: CEL runs rich
ok update. i just found a blown fuse. there are three fuses at the battery and the RAD VENT. /RAD FAN was burnt out. and it was fine last time i looked do u think it might of caused the car to run bad?
