Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-24-2008, 09:08 PM
ron73440 ron73440 is offline
1993 Cutlass Ciera almost dies when you push the gas
Don't know why I wrote 1993 she's a '91. First off, I'm new here and hope you can help before I pull my hair out. My car (3.3L V6 with 220,000 miles on it) started idling rough and runs if you push the gas pedal a couple inches, anything past that and it stumbles and runs really slow and sometimes dies. Feul pressure is good, plugs and wires are all good . Catalytic converter is only about a year old and there is no blockage in the air intake. Could it be the coils? I don't know how to check those. Any help would be appreiciated.
I've had her for three years and 115, 000 miles, no problems only had to replace the alternator and water pump.
Old 06-25-2008, 09:14 AM
maxwedge maxwedge is offline
A990 racer
Re: 1993 Cutlass Ciera almost dies when you push the gas
Welcome to AF. Did you actually test the FP, also, how about the fuel filter?
Old 06-25-2008, 09:24 AM
I tested the fuel pressure and the first thing I did was change the filter just hoping that was it. Also the check engine light came on sporadically but doesn't any more so I can't get any codes.
Old 06-25-2008, 04:07 PM
A990 racer
Again!!! How much pressure?
Old 06-25-2008, 07:12 PM
40 when the key is turned on, 36 when engine is started, doesnt change when you push the gas and the engine sputters, and when you unplug the vacuum from the fuel pressure regulator it jumps to 44
Old 06-25-2008, 09:20 PM
A990 racer
Good we are past the FP issue. Try disconnecting the MAF, see what happens or tap it firmly and see what happens, also try tap testing the ECU, they are known to be an issue on these cars, if all checks, I would have the ign module tested, AZ and/ or Napa can do this, but it may not be conclusive. A full scan should pick up history codes.
Old 06-27-2008, 12:36 AM
cieraranger cieraranger is offline
Send a message via MSN to cieraranger
I know you have a '91 (I have a '93' 3.3) but I had a problem close to that. If you are cool with it pull the MAF sensor and look at the filaments close. I had a bunch of stuff on mine and brake cleaner and my brush from an electric shaver gently cleaned it up and bamm, back to a spunky ride.
Old 07-16-2008, 07:49 PM
sorry it took me so long to answer, do you mean take the maf off? when you unplug it the car tries to die and tapping it didnt change anything so would it still be inside the maf? thanks for trying
Old 07-16-2008, 07:59 PM
A990 racer
Usually that indicates the maf is probably not the problem.
Old 08-26-2008, 09:57 PM
Mikey_G Mikey_G is offline
Have you checked the fuel injectors?
