Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 06-24-2008, 06:16 PM
JbreezeintheB2000 JbreezeintheB2000 is offline
Question 84 b2000 will not crank
my 1984 mazda B2000 sundowner that i am working on will not start
i have my dad help try to fix it. It seem that the problem is that the motor had no fire and we have check the coil and distributor.
so what will the problem be.
if anyone has any parts for sale also please
i need the vechile on the road soon
Old 07-04-2008, 01:03 AM
toddluck69 toddluck69 is offline
Re: 84 b2000 will not crank
if your coil is good it could be the ignition switch to test take a wire from the + side of the battery to the + side of the coil and jump the starter off with a screw ddriver if it fires your switch is bad just remeber the only way to shut the truck off will be to pull the wire from the battery
Old 07-05-2008, 11:37 PM
OldSchool B2000 OldSchool B2000 is offline
I have a 2 1984 B2000 I am parting out. The body is shot for the most part. It is the same on the inside. It has the running gear: engine,tranny,and axle the in good shape. Let me know if you or anyone else needs parts. Just ask, I might have it. Keith
Old 07-24-2008, 12:52 PM
i have replace the ingintion pick-up, and the inginition module. what else could there be
Old 12-17-2008, 09:10 PM
any help please
