Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 06-24-2008, 05:04 PM
nutbushchris77 nutbushchris77 is offline
Cool A/c Problems For 1997 Dodge Neon Help!!!
I Know I Got A Leak In It, Because I Put Freon In It And A Week Later Its Gone. What I Am Trying To Do Now Is Shoot Some In It But The Compressor Won't Come And I Can't Find The Low-pressure Cycling Switch To Put A Jumper Wire On It, So The Compressor Will Come On. Can Anybody Help Me With This Please!!!
Old 06-25-2008, 08:21 AM
angus10 angus10 is offline
Re: A/c Problems For 1997 Dodge Neon Help!!!
Does this help
1998 Dodge Neon A/C Low Pressure Cut Off Switch
98 Ram 1500 4x4
Flowmaster American Thunder W/super40
Old 06-25-2008, 01:18 PM
Do I Run A Wire From One Prong To The Battery, Or Is It Going To Be Two Separate Wires. One To Each Prong And Both To The Battery.
Old 06-25-2008, 01:30 PM
brcidd's Avatar
brcidd brcidd is offline
you put a paper clip across the wiring harness terminals that plug into this switch- and don't let it touch metal...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-25-2008, 03:39 PM
so i stick a paper clip in both sides of the harness (booth) and thats it. I don't have to hook it back up to the switch or run a wire to the battery or anything.
Old 06-25-2008, 07:38 PM
I did the jumper and the compressor did not come on. Is there anything else i can do to make the compressor come on.
Old 06-25-2008, 09:31 PM
Old 06-26-2008, 05:05 AM
You only jump it to get the 134a to suck into the system . Put 1 can in while its jumped then remove the wire and put the plug back to the switch and see if the compressor cycles. If it does, then fill it to the proper pressure.
98 Ram 1500 4x4
Old 06-26-2008, 11:57 AM
I had the gauges hooked up and open while i did that and it didn't suck the 134a and the compressor didn't come on. The clutch won't turn.
Old 06-26-2008, 01:04 PM
You are unplugging the connector from the switch when you jump it right?
98 Ram 1500 4x4
Old 06-26-2008, 01:13 PM
And what do you mean that you had the gauges OPEN?
98 Ram 1500 4x4
Old 06-27-2008, 09:58 AM
Yes i am unplugging the connector,( you mean the boot that goes on the switch right).
Old 06-27-2008, 10:02 AM
I mean the gauges were hooked up and the 134a can hooked to the yellow hose. the low side hooked up and high side hooked up.I opened everything so if the cluth turned by the jumper it will suck in the freon.
Old 06-27-2008, 11:38 AM
So when you jump the low side switch the compressor does not turn. Check the fuse and relay. Unless the comp. is running it won't take the 134 you are correct. You can try jumping the high side switch also. But be careful and just see if turns. If it does the the hi side switch may be bad or you have a wiring prob. And quite possible the ac button inside the car is not working.
98 Ram 1500 4x4
Old 06-27-2008, 12:18 PM
I might be doing the jumper wrong. What i do is put a paperclip across the prongs on the switch or stick the paperclip in the 2 slots of the clip with wires coming out of it.
