Old 06-24-2008, 04:26 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Bolt Missing, Anyone know the size?
Hey guys, hoping someong might be so kind as to remove a bolt on their GTP and measure it size/threads/lengh so I can buy one from a hardware store.
Replaced the valve cover gaskets one day and while I was putting things back together, dropped this bolt. It didnt hit the ground and I was getting close to being late for work so I had to finish up and go.
Its the bolt that bolts together the EGR heat shield to the MAP bracket. I attached a picture, but you guys might not be able to really see anything.
I've been driving with it like this for a while because I dont think its hurting anything. Just want everything complete.
Thanks for any info guys!
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 06-25-2008, 10:25 PM
tblake's Avatar
In God We Trust
Re: Bolt Missing, Anyone know the size?
Anyone?
Old 06-25-2008, 10:42 PM
doctorhrdware doctorhrdware is offline
Looks like it might be 1/4" or mabe smaller, maybe? Just a educated guess. What is the bolt for and I can take it off my car and take a measurement. Boy do I feel dumb if I would have read the complete post I would have found out the location. Is that the front side or is it the back side.
Old 06-25-2008, 11:04 PM
tblake's Avatar
In God We Trust
Thank you so much!
It will be a metric bolt. The head size was 10MM I believe. Its between the EGR valve and MAP sensor.
Old 06-25-2008, 11:07 PM
I will do it this weekend, when I do not have to work or Doctor's appointments had one today and two tomorrow.
Old 06-26-2008, 08:07 PM
tblake's Avatar
In God We Trust
Thanks so much! Take your time! Good luck at the Appointments...
Old 07-06-2008, 07:39 PM
The size is either 5mm or 6mm dia length is about 10 mm, used a caliper digital. You were right it is a 10mm head size. Sorry that I did not get to sooner I have been in the hospital. Got out Thursday. More lower back problems, have to wear a back brace now.
Old 07-06-2008, 08:30 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Be sure to get a flanged head bolt, otherwise you will need a washer that will be dropped next time you remove it!!
Old 07-06-2008, 11:02 PM
tblake's Avatar
In God We Trust
Thanks guys! Appreciate the help!
Nice Sig HotZ28! Looks familiar. Do we have pretty much the same cars?
Old 07-06-2008, 11:19 PM
That is one thing that I forgot to mention about the bolt. I would get one if possible where the flange has ridges that work like lock washer.
Old 07-13-2008, 12:19 PM
Tblake,
Did you get the bolt for your car that you dropped.
Old 07-13-2008, 10:33 PM
tblake's Avatar
In God We Trust
Nope, not yet. Next time i'm at the hardware store I'll pick one up. Thanks for the help though.
Old 07-13-2008, 10:36 PM
Was just wondering. Thanks for the update.
