Old 06-24-2008, 02:26 PM
hink12341234 hink12341234 is offline
04 Cavalier-ABS yes or no?
Was anti-lock brakes standard on 04 Cavaliers or was it an option? If it was an option what's the quickest way to find out if the car does have ABS? Thanks!
Old 06-24-2008, 02:30 PM
discnik discnik is offline
Re: 04 Cavalier-ABS yes or no?
Look on the inside front or rear wheel well. If it has ABS there will be a wire going to a sensor on or near the hub. If there is only a brake hose going to the wheel area then there is no ABS.
Old 06-24-2008, 11:50 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
It was an option 2003-2005.
it was standard 95-02.
Guy above stated the best way to check for it. Or pop the hood and look at your proportioning valve off the master cylinder. If its just an aluminum block with 2 lines in and 4 out, you don't have it. If there electric wires running into it, you have ABS.
In this photo is without ABS....
Note the sliver proportioning valve block with just lines coming in and out.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 06-26-2008, 01:07 AM
Jacfourteen Jacfourteen is offline
damn, I wish that it was an option in 95-02 then maybe my 97 would have came without it! (I hate ABS on these cars)
99 Explorer (my daily driver)
-2" lift, 31" tires
-Magnaflow muffler
-7" Touch screen DVD stereo
-12" drop down LCD monitor
02 Mustang Convertible (wife's)
-K&N Filter
-Flowmaster 50
68 GMC (project)
-300 HP 350
Old 06-26-2008, 01:20 PM
bondo07's Avatar
bondo07 bondo07 is offline
easy way to disconnect it, unplug it from the master cylinder. Brakes are a little softer, but no abs!
Old 06-26-2008, 04:17 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Or you could just find a large gravel lot, get going, and slam on the brakes. Listen for the ABS grinding noise! Problem solved!
Old 06-26-2008, 05:43 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
then just disconnect it, there are numerous ways to make your ABS stop working, one painfully easy way is to just remove the ABS fuse from under the hood
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
