Go Back   Automotive Forums Car Chat > Dodge > Shadow
Old 06-24-2008, 01:38 PM
Tr7285 Tr7285 is offline
Help
1993 Dodge Shadow 2.2 automatic Wont start , When it DOES start it stalls when you stop , When goin up a hill it sputters and loses power under load , But if you shift it to a lower gear it will continue going then you have to drop it back into gear again . Put new Fuel filter on it, Checked the Rockers under valve cover , and he reset the timing on it, Any other suggestions ?
Old 06-24-2008, 06:59 PM
rhandwor rhandwor is offline
Re: Help
Check the fuel pressure you need to determine if its a fuel or electrical problem.
Old 07-05-2008, 11:00 PM
comp comp is offline
Re: Help
did you find a loose elec. connecter ?
Old 10-29-2008, 08:28 PM
daytonagord daytonagord is offline
Re: Help
test fuel preasure, change spark plugs, for starters
Old 12-08-2008, 06:58 AM
PWMAN's Avatar
PWMAN PWMAN is offline
Re: Help
Any fault codes stored?
http://www.knizefamily.net/minimopar/fault/index.html
My first guess would be the injector going bad, I assume this is a TBI engine.
88' Dodge Shadow- 2.2L, 5 speed...a couple mods
[email protected] MPH
