Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-24-2008, 08:29 AM
fst100 fst100 is offline
Unhappy HELP: cant fix the CEL light
I recently bought a 4G37 5-speed eclipse. When I bought it the CEL light was on but I had no way of scanning it. Will after some research I was able to get the codes via a volt meter. The codes were the following:
Barometric Pressure
Engine Coolant temp sensor
Air Intake Temp
ISC-idle speed controller off
Now I went ahead and bought parts from the junk yard to replace the ‘bad’ or faulty components such as throttle-body, ECT sensor, and a MAS assembly. I still get the CEL codes even after the parts were installed and I disconnected the negative battery for a few minutes.
I then bought a datalogger and had a palm pilot to use to read and scan what the ecu was getting. I noticed the TPS % was stuck at 99.6%, both Coolant and Air intake temps were -77.x*F!!! something tells me either the ecu is bad somewhere on the circuit board or possibly a bad ground? It doesn’t make sense. Any help is greatly appreciated. Thanks!!
edit-by the way i also replaced the t-stat with a 180* and the coolant temp needle on the dash is just before the half-way point.
Old 06-24-2008, 09:51 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: HELP: cant fix the CEL light
If it isn't a voltage issue, my bets are on ECU.
Kris
2012 Genesis Coupe 2.0t
Old 06-24-2008, 09:52 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Same thing happened to my Oldsmobile. Said this and that were going bad and replaced each one, even though most checked out in near perfect shape. After a while, took the car in and the ECU was gone. Sounds like the same thing.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-24-2008, 10:00 AM
will heres the other part of the story i didnt add in. when i bought the car, it already had the cel light, but i didnt get it scanned yet. a few days later the capacitor leaked in the ecu and the car didnt fire up, only cranked. i then went and bought a reman ecu that alreayd had the 3 caps swapped with higher temp caps but it looked like the person who did the soldering used a bit too much of solder as it was a messy job they did. that was when i scanned the car and pulled the CEL codes.
i also bought a haynes manual but i only was able to test the voltage off the MAS sensor wiring harness. i tested using the volt meter and probed the port 1 and it checked out with what the manual said, IIRC ~12v, then tested the port 2 off the MAS sensor wiring harness and it pulled ~4-5v just like the manual said.
Old 06-24-2008, 10:10 AM
DAVID-B, i tried reading what you wrote, but im having a hard time understanding what you meant. sorry, didnt mean to offend u if i did.
Old 06-24-2008, 11:32 AM
david-b's Avatar
Dave is THAT guy
-ECU threw codes for different senors
-Replaced those sensors
-More codes from ECU
-Was bad ECU
Not offended, didn't think it was that hard to understand to begin with.
75 Monte Carlo
Old 06-24-2008, 11:42 AM
ok, that makes more sense, thanks david-b. im in the process of getting another ecu, dunno if its gonna be a waste of money, but its worht a shot i suppose...
Old 06-24-2008, 11:22 PM
shawnnd1 shawnnd1 is offline
Ok I have to agree with everyone on here. the question i have for you is have you ever soldered anything like that before? You can clean them up and see if any joints tuched in the wrong area or if the traces are bad. There are ways to fix it but like everyone else said the ecu is probably the problem. There is one company I would trust to buy from and thats motoguys garage.com you can google it for there site address.
Old 06-25-2008, 12:25 AM
kjewer1 kjewer1 is offline
AF - Advisor
IIRC, all of those sensors are 5v sensors. But you say that the 5v at at least one of them was good? Check the manual and see if they all share the same sensor ground or something. Seems odd that a whole bank of 5v sensors woudl shit the bed at the same time. The 5v will come from inside the ECU.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
