Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-23-2008, 11:59 PM
deaertmule deaertmule is offline
99 burb window regulator
the motor seems to be shot and something is broken in the regulator mechanism so my D/S window doesn't operate correctly..i have a new reg/motor assy coming...are there any tricks to changing this out? TIA
Old 06-24-2008, 02:59 AM
emt1134 emt1134 is offline
Re: 99 burb window regulator
The regulator is riveted in, not bolted. You must remove the old rivets.. Best way to do it would be to use a cutting wheel to make an "X" in each rivet, then punch 'em out. If you can't do that, then use a chisel to break them away.
Old 06-27-2008, 08:31 PM
ended up drilling and chiseling the rivets out...pretty simple swap...works like a champ now..thanks for the reply emt1134..
