Go Back   Automotive Forums Car Chat > Buick > Century
Old 06-22-2008, 10:15 PM
wbill3336 wbill3336 is offline
1994 centurty please help me someone
just started to day it wont start all the firing is good if ya get it to start it spits sputters and back fires can spray a little eather in it and will run fine for a little while changed the mass air flow sensor spent 130 dollars for nothing on that dont know where the fuel filter is if some one could tell me i will try that next then on to the fuel pump i guess hope some 1 can give me some good tips
Old 06-23-2008, 08:53 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1994 centurty please help me someone
Welcome to AF.
For fuel filter: Under vehicle, center, below trunk area, near fuel tank, mounted in fuel line.
Check fuel pressure at the fuel injector rail. There is a Schrader valve where you can connect an automotive fuel pressure tester.
Timeslip 08/12/06
AF Community Guidelines
Old 06-23-2008, 10:21 AM
Scrapper Scrapper is offline
AF Premium User
sounds like your going to have to put a fuel pump in it and you have to drop tank to put it in...sounds to reason that you spray starting fluid and it'll run. good luck...scrapper1
