Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 06-22-2008, 08:12 PM
cncvandy cncvandy is offline
distributor shaft won't turn!!!!1
I replaced the head gasket on my 2.5 89 lebaron and I put on a different head...I thought I had the cam gear on the same way as the old head...but when I tryed to start the car I guess it sheared something that drives the distributor ....Can anyone tell me if I killed the engine or is there something I my do to save the engine....PLEASE HEL!!!!!!
THANKS FOR ANY HELP
Old 06-23-2008, 04:27 PM
KManiac's Avatar
KManiac KManiac is offline
Re: distributor shaft won't turn!!!!1
The distributer is driven off of a secondary shaft, not the camshaft. Check to see if your camshaft is turning. It is possible that the timing belt lost tension from a lose tensioner bolt or did not get tightened up right to begin with when you reassembled. If neither the camshaft or the distributer turn, then you need to reset the timing belt and tensioner. No worries because the 2.5 in a non-interference engine. But if the camshaft turns and the distributer does not, the problem is in between the secondary shaft and the distributer. I don't think your engine is ruined.
Let us know what you find and what you do.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
