Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 06-22-2008, 06:58 PM
infamouspdp infamouspdp is offline
Dim Headlights
i can hardly see at night because of the dimness of my headlights.it seems like the brightness of high beam should be low beam.you can look at them when they're on and tell they are really not bright as they should be.i even replaced them yesterday with some so-called brighter bulbs,but no difference.could there be a wiring or relay issue that would cause this?
Old 06-22-2008, 08:05 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: Dim Headlights
make sure the lense is clear, then after that it is most likely the socket that is either corroded, or burnt, those sockets can be easily found at any good auto parts store, and wired up by a child.
Don't act like you don't love it.
503/2000
Old 06-23-2008, 09:44 AM
808drifter 808drifter is offline
Re: Dim Headlights
Or maybe just spoiled by HID's.
Old 08-16-2008, 04:14 AM
perna00's Avatar
perna00 perna00 is offline
Send a message via AIM to perna00
Re: Dim Headlights
Check your wiring connections. Those "Brighter" bulbs will actually melt the stock harness connections. Had to replace them with bigger wiring near the bulbs. The increased heat transfers from the bulb. Also, check to make sure you are getting 14.5 volts to them while the car is running.
