Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-22-2008, 06:50 PM
Bonnevilleracer Bonnevilleracer is offline
Send a message via AIM to Bonnevilleracer
More hosrepower!!!!!
I have a 95 Bonne, It was my daily drvier for a few years, but now i'm driving an S-10. I tried the car into a full out race car (Full roll cage, racing seat, no interior). I race on a 1/4 oval track in NH. Now here's the kicker, The divison I race in is a full size class. All the other cars are V-8!
I need any and all info i can get to make my car whip some v-8 butt.
I have to stay within the rules, which are:
1) Complete Stock motor
2) Complete Suspention
3) No turbo or superchangers
Please, I need help! Iwant to show everyonethat V-6's can infact show up some V-8's
Old 06-23-2008, 03:21 AM
my85olds442 my85olds442 is offline
Re: More hosrepower!!!!!
I am not trying be wise here but the old saying "no replacement for displacement" may hold true in your case if you must stay Stock.. I guess you can pick up 2-5 hp by using a K-N air filter and maybe 1-2 more by using synthetic oil. Can you free up the exhaust any? If you can get away with it that is where I would look first.
Stefan
Old 06-24-2008, 08:52 AM
I have a K&n on it and I have the exhaust cut alittle bit after the cat
Old 06-24-2008, 09:47 AM
well in that case, you can "rod out" the CAT and use the least restrictive muffler you can find. Just be aware the these motors like a bit of back pressure and cutting the pipe in back of the CAT may cost you some HP...
Old 06-24-2008, 10:51 AM
Jrs3800 Jrs3800 is offline
For the Motor.... You can yank and Port match the lower intake to the heads... If you do not port the heads, Give the Port opening a slight chamfer around the edge so that the air entering the cylinder does not hit a wall of sorts...
Also you can go to a ported Front Manifold, this will help increase the flow out of the front bank a little...
If you know anyone with a Mill you may be able to have the Throttle shaft shaved down a bit...( every little bit counts )
Gut the Air Box( remove the Baffled in the front of and rear of the air box ), Once you have done that Cut the front of the Box open behind the headlight... And get that K&N filter
As for the suspension.... Does it have to be stock to the car? Or stock on a Full Sized Bonneville? Other Models of Bonneville used the FE2/F41 Handling suspensions... Stiffer springs and larger sway bars..
